badhemi Posted December 4, 2016 Posted December 4, 2016 Has anybody got this running it seems to be crashing
Guest Posted December 5, 2016 Posted December 5, 2016 On 12/4/2016 at 11:52 PM, badhemi said: Has anybody got this running it seems to be crashingCheck the RA logs and make sure you have the required bios files. Check the core info files for required bios Sent from my iPhone using Tapatalk
badhemi Posted December 5, 2016 Author Posted December 5, 2016 On 12/5/2016 at 11:37 AM, tonesmalone said: Check the RA logs and make sure you have the required bios files. Check the core info files for required bios Sent from my iPhone using Tapatalk Expand Yes I have machine folder with correct bios
Guest Posted December 5, 2016 Posted December 5, 2016 On 12/5/2016 at 12:55 PM, badhemi said: Yes I have machine folder with correct bios Expand Right. Have you checked the RA logs?? Is your RA system folder set correctly?? Is the machine folder in your system folder??
thatman84 Posted December 5, 2016 Posted December 5, 2016 @tonesmalone FYI it's really hard to get logs on Android Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
Guest Posted December 5, 2016 Posted December 5, 2016 On 12/5/2016 at 1:09 PM, thatman84 said: @tonesmalone FYI it's really hard to get logs on Android Expand Why? Surely you can access the file system?
thatman84 Posted December 5, 2016 Posted December 5, 2016 Afaik you have find a app but I couldn't find a good one, or setup a terminal adb connections rom PC and run a command to print it to a text file. Which works well once it's setup Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
Guest Posted December 5, 2016 Posted December 5, 2016 On 12/5/2016 at 1:16 PM, thatman84 said: Afaik you have find a app but I couldn't find a good one, or setup a terminal adb connections rom PC and run a command to print it to a text file. Which works well once it's setup Expand Yeah figured you could use ssh or something similar. Worth doing - logs are important in tracking down errors like this.
thatman84 Posted December 5, 2016 Posted December 5, 2016 No doubt helped me sort custom rom folders for retroarch MAME core really quickly Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted December 5, 2016 Author Posted December 5, 2016 On 12/5/2016 at 12:56 PM, tonesmalone said: Right. Have you checked the RA logs?? Is your RA system folder set correctly?? Is the machine folder in your system folder?? Expand Yes its in my system folder
