Demuel hiding mouse
mikea213
What emulator for what system are you using?
Be specific and try to give as much information as you can, that way it will be easier to found out the problem. :D
Open Rocketlauncher UI, in the left panel, select the system you want to disable the cursor, in the Main Settings tab, set Hide Cursor to True. Here's a capture of the menu location:
