Bonoscot Posted December 27, 2016 Posted December 27, 2016 Guys im in the midst of setting up a new bartop arcade.....Hyperspin so far so working fine (the games that i have tried anyways) I built the bartop to play PC games as well (loaded via hyperspin) I cannot get the keys to map properly on this game at all.....The menus move via the joystick,but when i get to character screen it doesnt work,nor in game fight Has anyone got this working? IM really stuck,been on this for about 4 hours now
Metalzoic Posted December 27, 2016 Posted December 27, 2016 Yes. MKXL will not normally work with an iPac. there are work arounds. There are a couple topics here with my info.
Metalzoic Posted December 27, 2016 Posted December 27, 2016 A quick search pulled this up And also this topic with more info on DevCon and how to do it Basically you need to install and setup Vjoy and activate it in RocketLauncher as one of your keymapper programs. This is where to start. If all is good you're set. OR - If you don't want Vjoy conflicting with other emulators or games (AAE #2 emulator... a few PC games etc...) you can install and setup Vjoy, and also install DevCon, then run a start/stop script like I do when MK XL launches instead of running it as an RL keymapper.
Bonoscot Posted December 27, 2016 Author Posted December 27, 2016 ye i used Vjoy..outwith HL at the moment.. I even set my buttons to the exact same they have in game....ie F (high punch) , so i setup F up in VJoy..........still no luck......The game lets me move within Menu but not in game.... Is there a proper tutorial i can follow.... I actually cant believe this....i specifically have built a bartop to play Mortal Kombat XL and Injustice (drilling 8 button holes) for me now to find out that these games dont run on an Ipac (or have problems)
Metalzoic Posted December 27, 2016 Posted December 27, 2016 10 hours ago, Bonoscot said: Is there a proper tutorial i can follow.... Other than what I linked above (and the links to more info with them) not that I know of. Just follow that and it should work. After you built your profile for the game did you turn it on in RocketLauncher under the Keymapper settings? For example (from Shank):
