NEC Turbo Graphx 16 not playing preview videos
mankin
Hi:
I setting up my Hyperspin and have got a few systems running fine now except Turbo Graphx 16 won't show preview videos on a selected game wheel. All the other systems show preview videos for selected games except for Turbor Graphx 16. I'm sure I have HyperHQ pointed at the correct directory and folder. Can someone point out where I have gone wrong. Below is the settings INI for MAME which shows preview videos correctly for the games and then the Turbo Graphx 16 INI settings. Thanks in advance.
[exe info]
path=
rompath=D:\Games\Romsets\Mame 0.179\Roms
userompath=true
exe=
romextension=7z,zip,rar,chd
parameters=
searchsubfolders=true
pcgame=false
winstate=HIDDEN
hyperlaunch=true
[filters]
parents_only=true
themes_only=false
wheels_only=true
roms_only=true
[themes]
use_parent_vids=true
use_parent_themes=true
animate_out_default=false
reload_backgrounds=false
[wheel]
alpha=0.15
small_alpha=1
style=normal
speed=high
pin_center_width=500
horz_wheel_y=512
vert_wheel_position=right
y_rotation=center
norm_large=360
norm_small=230
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=384
[video defaults]
path=D:\Games\HyperSpin\Media\MAME\Video\
[sounds]
game_sounds=true
wheel_click=true
[exe info]
path=
rompath=D:\Games\Romsets\Turbo Graphix 16\Roms
userompath=true
exe=
romextension=pce
parameters=
pcgame=false
winstate=HIDDEN
hyperlaunch=true
[filters]
parents_only=false
themes_only=false
wheels_only=true
roms_only=true
[themes]
use_parent_themes=false
reload_backgrounds=true
[wheel]
alpha=.15
small_alpha=1
style=normal
speed=high
horz_wheel_y=512
y_rotation=center
norm_large=400
norm_small=240
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
text_stroke_size=6
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=384
[video defaults]
path=D:\Games\HyperSpin\Media\NEC TurboGrafx-16\Video\
[sounds]
game_sounds=true
wheel_click=true
assuming you have a system theme for TG-16.. and have HyperHQ pointing to the correct folder with the videos, and they are in the correct format (which shouldn't even be a issue but could be) and the file names match exactly to the rom names... it should work but I do remember having a problem getting tg-16 videosnaps to show but I believe my problem was due to a mixup with  PCE and TG-16.. I may have been using PCE themes and media with TG-16 roms.. but to my knowledge the file names for PCE and TG16 matched.. don't know what I did to get it working but definitely check that the file names match.
Thanks for the reply,
I've checked the file names for the videos (flv and mp4) and the names match the rom names. I have the theme as the NEC TurboGrafx-16 - System Default (16:9ST) in the Hyperspin/media/NEC TurboGrafx-16/Themes as default.
Out of curiosity I ran default Hyperspin 133 and the sample video (Aero Blasters) played in the preview screen. So I tried deleting the theme in my Hyperspin and replacing it with the Hyperspin 133 theme as default in NEC TurboGraphx-16 and it didn't look right at all; there wasn't even a box where the video preview would appear.
So I'm still stumped.
maybe try to find some TG-16 game themes.... that could point you in the right direction because if you add the game themes and the videos show up then you know it's a issue with the system theme. hopefully someone with more knowledge comes by to help... just mentioning somethings that helped me out in the past.
you should consider downloading this 3rd party app
download and it and extract it to your hyperspin folder
C:\Hyperspin\HyperTOOls.exe
this tool will scan your media folders and tell you what is missing.  More importantly it will find media that is not being used or is missed matched to your XML.
I made a very quick tutorial on how to use the program here
audit your image folders to make sure every media item matches your XML, and then we can see if you still have a problem.
Rastan & 32assassin:
Thank you both for your suggestions I'll definitely look into both of your suggestions. Fingers crossed.
  • 4 weeks later...
So I got sidetracked and was only able to get back to this now. I decided to delete everything in my video folder and re-download the video snaps from emu movies and viola it works now.
