Hillage Posted January 2, 2017 Posted January 2, 2017 Hi there! Is it possible to hide emulators until you press a certain key? My example is that I only want MAME to be visible, but if you press a certain shift key set up through an ipac, the other installed emulators appear. Thanks!
griffin518 Posted January 2, 2017 Posted January 2, 2017 That's a good idea, but not possible that I know of. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
Metalzoic Posted January 3, 2017 Posted January 3, 2017 Well you could maybe setup a script that launches your MAME HyperSpin, but a certain button combo closes that HyperSpin and launches another with everything else. Or maybe have 2 instances of HS running and write a script so a button combo changes focus between them... Or check the thread here with instructions on creating multilayered HyperSpin setups etc...
Hillage Posted January 3, 2017 Author Posted January 3, 2017 On 1/3/2017 at 1:49 AM, Metalzoic said: Well you could maybe setup a script that launches your MAME HyperSpin, but a certain button combo closes that HyperSpin and launches another with everything else. Or maybe have 2 instances of HS running and write a script so a button combo changes focus between them... Or check the thread here with instructions on creating multilayered HyperSpin setups etc... Expand Thanks for the info. I was unable to find the multilayering thread you speak of, but I might be able to whip up a script that can run on a specific key press. If I am successful I'll post the results.
Metalzoic Posted January 3, 2017 Posted January 3, 2017 On 1/3/2017 at 3:00 AM, Hillage said: Thanks for the info. I was unable to find the multilayering thread you speak of, but I might be able to whip up a script that can run on a specific key press. If I am successful I'll post the results. Expand Yeah the search function on this site sucks demon balls. It's almost completely useless. If I find the topic I'll link it here for you.
griffin518 Posted January 3, 2017 Posted January 3, 2017 Maybe this is something EDS could be used for? Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
Hillage Posted January 3, 2017 Author Posted January 3, 2017 On 1/3/2017 at 3:55 PM, Metalzoic said: What's EDS? Expand I don't quite fully understand it, but it is something I'll have to look into for sure.
