mar00n Posted March 29, 2014 Posted March 29, 2014 I have setup a new hyperspin system on my smaller computer, it has a very small solid state drive and 1tb second drive. I have placed hyperspin on the D: drive and configured it ready to go. I opened up HyperlaunchHQ and pointed it to my hyperlaunch directory. Games run fine from hyperlaunch but when it comes to launching any game from hyperspin it says "could not find hyperlaunch.exe". I can't move hyperlaunch to C: either due to lack of space. I have read other posts and tried their solutions but there is no such file as system.ini or settings.ini I can find. Please help My Hyperspin system so far: Atari 5200 100% -Atari Jaguar 100% -Atari Lynx 100% -Gameboy 100% -Gameboy Color 100% -NEC TurboGrafx- 16 100% -Nintendo 64 100% -Nintendo Entertainment System 100% -Nintendo Gameboy Advance 100% -Nintendo Virtual Boy 100% -Sega 32X 100% - Sega CD 100% -Sega Game Gear 100% -Sega Genesis 100% - Sega Master System 100% -Sega Model 2 100% -Sega Saturn 100% -SNK Neo Geo 100% -SNK Neo Geo Pocket Color 100% -Super Nintendo System 100%
mar00n Posted March 29, 2014 Author Posted March 29, 2014 07:31:29 PM | HyperSpin Started 07:31:29 PM | Going FullScreen 07:31:29 PM | Checking for updates 07:31:29 PM | Update Check Complete 07:31:29 PM | Startup program unavailable 07:31:29 PM | Playing intro video 07:31:32 PM | Error intializing joysticks 07:31:32 PM | Menu Mode is multi 07:31:32 PM | Loading Main Menu.xml 07:31:32 PM | Main Menu.xml successfully loaded 07:31:32 PM | Main Menu wheel loaded successfully 07:31:33 PM | Loading Sega SG-1000.xml 07:31:33 PM | Main Menu.xml successfully loaded 07:31:34 PM | Sega SG-1000 wheel loaded successfully 07:31:34 PM | Launching Game 07:31:34 PM | Using HyperLaunch 07:31:34 PM | Getting HyperLaunch path 07:31:34 PM | HyperLaunch located at D:\Hyperspin\HyperLaunch.exe 07:31:34 PM | Cannot find Hyperlaunch.exe 07:31:40 PM | Loading Main Menu.xml 07:31:40 PM | Main Menu.xml successfully loaded 07:31:41 PM | Main Menu wheel loaded successfully 07:31:42 PM | Exit program unavailable 07:31:42 PM | Quiting Hyperspin 07:31:42 PM | Bye! My Hyperspin system so far: Atari 5200 100% -Atari Jaguar 100% -Atari Lynx 100% -Gameboy 100% -Gameboy Color 100% -NEC TurboGrafx- 16 100% -Nintendo 64 100% -Nintendo Entertainment System 100% -Nintendo Gameboy Advance 100% -Nintendo Virtual Boy 100% -Sega 32X 100% - Sega CD 100% -Sega Game Gear 100% -Sega Genesis 100% - Sega Master System 100% -Sega Model 2 100% -Sega Saturn 100% -SNK Neo Geo 100% -SNK Neo Geo Pocket Color 100% -Super Nintendo System 100%
Rick74 Posted March 29, 2014 Posted March 29, 2014 There should be a folder 'settings' In that folder if remember correctly should be a settings.INI Change the location from C://hyperspin.exe to D://hyperspin, or wherever your hyperspin.exe is located Actually after reading your logs, you need to redifine where hyperlaunch.exe is I'm not at a computer right now, do maybe someone else can be more help
rfancella Posted March 29, 2014 Posted March 29, 2014 mar00n said: I have setup a new hyperspin system on my smaller computer, it has a very small solid state drive and 1tb second drive. I have placed hyperspin on the D: drive and configured it ready to go. I opened up HyperlaunchHQ and pointed it to my hyperlaunch directory. Games run fine from hyperlaunch but when it comes to launching any game from hyperspin it says "could not find hyperlaunch.exe". I can't move hyperlaunch to C: either due to lack of space. I have read other posts and tried their solutions but there is no such file as system.ini or settings.ini I can find. Please help mar00n said: 07:31:29 PM | HyperSpin Started 07:31:29 PM | Going FullScreen 07:31:29 PM | Checking for updates 07:31:29 PM | Update Check Complete 07:31:29 PM | Startup program unavailable 07:31:29 PM | Playing intro video 07:31:32 PM | Error intializing joysticks 07:31:32 PM | Menu Mode is multi 07:31:32 PM | Loading Main Menu.xml 07:31:32 PM | Main Menu.xml successfully loaded 07:31:32 PM | Main Menu wheel loaded successfully 07:31:33 PM | Loading Sega SG-1000.xml 07:31:33 PM | Main Menu.xml successfully loaded 07:31:34 PM | Sega SG-1000 wheel loaded successfully 07:31:34 PM | Launching Game 07:31:34 PM | Using HyperLaunch 07:31:34 PM | Getting HyperLaunch path 07:31:34 PM | HyperLaunch located at D:\Hyperspin\HyperLaunch.exe 07:31:34 PM | Cannot find Hyperlaunch.exe 07:31:40 PM | Loading Main Menu.xml 07:31:40 PM | Main Menu.xml successfully loaded 07:31:41 PM | Main Menu wheel loaded successfully 07:31:42 PM | Exit program unavailable 07:31:42 PM | Quiting Hyperspin 07:31:42 PM | Bye! Rick is very close. There should a file called Settings.ini in your C:\HyperSpin\Settings folder. Open it up and look in the [Main] section for this line: Hyperlaunch_Path= Change it to where your HyperLaunch is installed. Your setup should be: Hyperlaunch_Path=D:\Hyperspin\HyperLaunch Hope this helps, Ron PS: As noted below. You can use the relative path: Hyperlaunch_Path=HyperLaunch\ Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
mar00n Posted March 29, 2014 Author Posted March 29, 2014 A very simple solution to a very simple problem. Many thanks fellas. I can push on now. Do you think it would be a struggle to get hyperspin to work on an external hard drive, would it be a case of just editing that file again to match to drive letter? My Hyperspin system so far: Atari 5200 100% -Atari Jaguar 100% -Atari Lynx 100% -Gameboy 100% -Gameboy Color 100% -NEC TurboGrafx- 16 100% -Nintendo 64 100% -Nintendo Entertainment System 100% -Nintendo Gameboy Advance 100% -Nintendo Virtual Boy 100% -Sega 32X 100% - Sega CD 100% -Sega Game Gear 100% -Sega Genesis 100% - Sega Master System 100% -Sega Model 2 100% -Sega Saturn 100% -SNK Neo Geo 100% -SNK Neo Geo Pocket Color 100% -Super Nintendo System 100%
ghutch92 Posted March 29, 2014 Posted March 29, 2014 mar00n said: A very simple solution to a very simple problem. Many thanks fellas. I can push on now.Do you think it would be a struggle to get hyperspin to work on an external hard drive, would it be a case of just editing that file again to match to drive letter? Will it be a struggle? maybe. Will it be that simple? no. It completely depends on what all you are transferring. If you originally installed it on an external drive with the same drive letter it will be easy. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
Awakened Posted March 29, 2014 Posted March 29, 2014 I found out recently that you can use a relative path there so you don't need to specify the drive letter. If you have your HyperLaunch folder inside your HyperSpin folder, Hyperlaunch_Path=HyperLaunch\ works.
mkarabinus Posted August 8, 2014 Posted August 8, 2014 I tried the direct paths and kept getting the error message. Then i tried the relative path as you suggested...it finally worked. THANKS!!!!!!!
