How to get WINVICE to work with Xbox 360 pad
demonseed
Hey Guys
I followed Austins tutorial on setting up Commodore 64 with winvice.  I got it to load and run games but I can not for the life of me figure out how to setup my xbox 360 controller to work with it. I would like to use the pad with now keyboard.  Any ideas?
He surely explained how to set controls and the different options you have?
I have my Ultrastik set to joystick in port 2, DO NOT set control for port 1. You should already have the Commodore 64.ini in the modules folder which should automatically set the joystick to port 1 or 2.
Unfortunately you will need to set keyboard controls for some games unless you know which ones just use the joystick.
For example Raid Over Moscow uses the C64 function keys which i had to map on my cab using a shift button. Even with those set F7 refused to work and that button is used to open the hanger door.
So I still have my Rii mini i8+ keyboard handy at the moment.
Does the c64 have standard keys for games or do they differ? Judging by the last post I may not be able to have it run only via the controller ?
  • 1 month later...
Hi,
Did you get this working? I set up the xbox 360 controller in the winvice system and games work fine. As soon i i run via hyperspin it creates a new vice.ini over writing the settings so the controller no longer works. How do you stop Hyperspin creating a new vice.ini
3 hours ago, Plastron said:
Hi,
Did you set "Save Settings on Exit" in WinVice?
yes but found setting DisableAutoControllerSwapping to true works joystick stay there now when running via hyperlaunch. not sure will work for all games but so far so good
