JOY2KEY Help
demonseed
Well I got super frustrated with xpadder and I am now trying JOY2KEY. Well it too is giving me a great deal of hassel. I have gone to GLOBAL and set a _defaul, a rocketlauncherUI and rocketlauncher profile... when I open them in RL they seem to work. When I click HS it is NOT loading the profiles? I do not undertand why not?...  OK so I did some digging, and here is what I have found so far.
If I go into GLOBAL/keymapper then open RocketLauncherUI it opens JOY2KEY. It has all my keys set there fine. If I leave it open and run HS all works.  So what is happening is somehow when I boot HS it is NOT loading the profile on startup.  How do I tell it do that?
I have checked the settings.. and the keymapper is set to Joy2key in main settings. and under third party all appears set to joy2key
**OK I got it sorted out in the HS menu now, I used the start up script to load joy2key and all works now there..
I can not seem to get the individual systems to load their own controls.. I setup a EMULATOR one under PopCap but it does not load/work?
Did you follow Spawks guide specifically associating your Hyperspin profile with Hyperspin so when HyperSpin runs that profile is loaded. So that is steps 4,5,6,7,8. What's really important is under preferences checking the box "Start JoyToKey in a minimized mode" and then make sure you save each profile. You must also check that box and save even if you create a black profile in RLUI.
Ok I do not get this.  I have joytokey turned on, under PopCap I went to keymapper and made a SYSTEM setting. I set the controls and made sure it is saved as PopCap.  I have the minimized settings checked.  When I load popcap not working.  I am not sure why.  Only thing I can think of is I used HyperHQ to make my wheel and loaded the games that way instead of RL?
