wardiz Posted February 2, 2017 Posted February 2, 2017 I am not able to open the supermodel emulator in hyperspin . I can get the games working with the supermodel-Ui It keeps coming up with this when I try and run it through hyperlaunch . Any help would be awesome . thanks
Metalzoic Posted February 2, 2017 Posted February 2, 2017 Not sure. Did you check module line #76 like that AHK error says? HyperLaunch is old and hasn't been supported since everything moved on to RocketLauncher. Did you just setup Supermodel? If so it's possible that your module was built for an older version.
Metalzoic Posted February 3, 2017 Posted February 3, 2017 On 2/2/2017 at 6:30 PM, agent47 said: That's a RocketLauncher module. If you're attempting to use that in Hyperlaunch it will not work, RL modules will only work with RL. Expand How did you tell it was an RL module? Checking the version? Actually how in the world did he get an RL module in HyperLaunch in the first place?
wardiz Posted February 3, 2017 Author Posted February 3, 2017 Thanks for your help , I setup the model 3 in rocket launcher and was able to get it working from the rocket launcher . But when I then start hyperspin and select a game for the model 3 that same error page comes up . i must have an incorrect ahk , the version of model 3 I'm using is 0.3a wip.
wardiz Posted February 3, 2017 Author Posted February 3, 2017 Here is the log from hyper spin. log.txtFetching info...
wardiz Posted February 3, 2017 Author Posted February 3, 2017 Thanks so much it works now , I've been trying to get it working over the past few days . Thanks everybody that helped .
