Need Help, Hyperspin opens and spins
zamo24
Starting to fill at end of a rope.  Way new to all this.  Bought external drive have done the bulk of the install.  However when I opened the first time I could see all of the different systems, now when I start up it goes directly to one particular system and to make it worse if I touch any button it just spins and sometimes freezes. crazy frustrated with the whole thing.  I would really appreciate any help and direction with this. Live in Southern California, access to condo and skiing on me and friend.  Thanks!
That was it.  Thank you very much!  I have an Xtension controller and now have to figure it out.  Have the video from gameroom and while some of that works I'm not getting full control.  I fix one problem and another comes up.  I cant even look at all the games that are on the drive so I probably have to put another post on here.  Thanks again!
If you bought a pre-built  drive you might be in for a really hard time getting it all to work right. Good luck.
EDIT: Ah, maybe I misunderstood and you just meant you bought a drive and installed it all yourself.
I bought the 6tb drive from HYPERSPIN and its far from plug and play.  They have helped and in fact told me about this site, it seems to be connected to this community.  But I think your hundred percent right, I have some work in front of me to get it all to work as advertised.  I see all the files on the drive as promised, but I can only  access AAE and that's it.  Something tells me its something to do with a setting on Hyperlink.  I'll contact them again and hopeful get onto a path to correcting this.  I'm open to any help and advise thanks for your time!
