MAME running to fast
Maximilium
Hello Peps:
Noob question:
I just recently installed HyperSpin, trying to set up the games on MAME, when I test, they all play too fast, I have a different MAME install and they run at normal speed, any advice?
thanks.
That is a problem with the mame.ini file. If the versions of your 2 mame setups aren't that far apart it would be quickest to move the working one over.
Otherwise you will have to mess with ini settings which may be a sync issue.
Remember to back up you ini files first.
The second version of MAME that works is the MAMEUI64, very different from the one I downloaded with the package. I will check the MAME.ini file to see whats the difference, I already reset to default and still not fix the issue.
And you've tried deleting the ini file and starting from default?
Do you ROMs match the MAME version?
Griffin512:
You send me on the correct path to fix this issue, thanks.
On the mame.ini folder there is 5 different configurations, Deleting mame.ini didn't fix the issue, it was when I deleted vector.ini, horizont.ini and vertical.ini that fix the speed but screw up the video set up,
Using Notepad++ with compare plug in I found the difference between files, the CORE PERFORMANCE OPTIONS need to be the same on all files:
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              1
Once I edited the files with Notepad++ speed problem was fix.
Here is mine
  Quote
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
Expand
Maybe look at this also ignoring the bgfx line.
  Quote
# OSD VIDEO OPTIONS
video                     bgfx
numscreens                1
window                    1
maximize                  1
waitvsync                 0
Expand
