HyperHQ crashes under win10
sork01
Whenever I press the button and the "Browse for folder" dialogues hows up, hyperhq crashes.
How am I supposed to chose the correct folder?
It's a known bug with Windows 10. You can get around it by going into the settings folder, find the "whatever system you are trying to set".ini file (ex Nintendo Entertainment System.ini), and open it with notepad and fill in the paths manually
Well it isn't a system i'm trying to set up. I'm trying to chose the folder for ledblinky. Where is the ini for that?
Had this issue with any path I would try to enter (roms/video/ledblinky). BATTLEDONKEY has the correct answer. You should see a main ini file that will have "LEDBlinkyPath=" something like that. Sorry Im not at home to check the correct file name but it is done the same way as video and rom paths. If you still cant find it I will look it up when I get home.
I had this issues as well mate but I just right click and select properties on Hyper hq.exe and run as windows 8 or 7 and click also run as admin.. this helps it 90 percent of times but if ya changing a heap of folders it will crash 1 time.. and then you start again..
Hope they fix it for win 10
I tried all the different comparability modes both with and without admin. Nothing changed, it still crashes.
Found the setting I was after in settings/settings.ini
