Lucasz1 Posted March 3, 2017 Posted March 3, 2017 So I unzip the default.zip file (my Sega CD Theme, in case), edit the xml with notepad++ and zip it again. It opens ok on Hyperspin. But when I try to open that zip on Hypertheme 1.1 the program crashes, leaving the message: "Error parsing zip". I´ve tried to zip with different programs and compressions, but the message persists. Any suggestions? I´m almost downloading/learing Photoshop to edit my themes.
sgeist28 Posted June 10, 2017 Posted June 10, 2017 I'm having the exact same problem. Some default.zip files are ok, but most present that error and it crashes HyperTheme 1.1. Has anyone found a solution for this?
volumetric Posted June 10, 2017 Posted June 10, 2017 I vaguely recall this being caused by not using the "store" compression method in winrar, but if you've already tried that, not sure what it could be.
sgeist28 Posted June 10, 2017 Posted June 10, 2017 Bingo that was it! Compression method. Next issue is I can't see MP4 videos Sent from my iPhone using Tapatalk
