nEW gUY
Tfan1138
I am new here meaning I know nothing about this program, I am at the point to where I might down load maxous arcade instead.
My issue is hyperspin, I have it set up but am having issues, I've read all I can and watched all i can but none of it has worked. I am getting can't find D/rocketlauncher and the rom name and i am having issues with my x-arcade tank stick for the games controls. Again I am not an expert at roms and need help fixing these issues, A step by step would help.
Have you edited the settings.ini file and added the location of rocketlauncher to it?
@Avar has some great tutorials I  the tutorial section of the forums if you haven't checked them out yet
if maximus arcade is going to give you less headaches.. go for it! you can have both of them installed on the same machine so perhaps as you work out your hyperspin issues... you'll at least have a functioning front end. it definitely sounds like you probably don't have RL location set up or something as the previous person mentioned. I think maximus works well with the tank stick.. or at least I remember X-Arcade having information on how to set it up. Good luck!
Have you already gone through all the setup tutorials here? Those should give you the step-by-step to set it up.
For the Tankstick use the search feature. There have been a lot of Tankstick threads since it sounds like it can be a bit tricky to get working right.
