Fromlostdays Posted April 14, 2014 Posted April 14, 2014 Austin, I'm not totally sure that Hypersync will "update" you to mp4 as in erase flv and replace with mp4. It may just see you have files with the right name and skip it - but try to standard sync vids first just in case. If that doesn't work, you have two options, but before we talk about that you should know that I'm not personally sure if all videos that exist as flv also exist as mp4, but just based on my own experience, I'd say its above 90 percent. The only ones I ever noticed missing were some oddball intro vids for unofficial systems. Having said that, you can do this one of two ways. Hypersync- as in you can go to media/system/vids and change the name of that folder (I'd call it the system name and just leave it, it'll make it less confusing.) then create a new folder called 'video' and sync with hypersync. You will now have all available mp4 vids. If you are worried you've lost a few, you can check each folder to see the number of files. If you have more flvs, the easiest thing to do would be to select all MP4 vids and paste them into your flv folder, and choose to overwrite all files. This will overwrite every flv that has the same name as an mp4, and leave the flvs that there is no mp4 equivalent. FTP You can also get on the emumovies ftp directly, pull all mp4 vids for a system and put them directly into your video folder with your flvs and choose to overwrite existing files. This will also leave any possible flvs with no equivalent in tact. I personally have noticed any difference in performance, but the mp4s do save some space. Goodluck, Walter:beerglass:
gigapig Posted April 14, 2014 Posted April 14, 2014 If I remember correctly Zerojay mentioned, due to a bug, having both can cause Hyperspin to crash. It may only be in attract mode and if left unattended, when the wheel lands on a game with an flv instead of mp4 or perhaps the other way round. Found the thread. www.hyperspin-fe.com/forum/showthread.php?33175-Is-anyone-still-working-on-Hyperspin-2-0/page4
rfancella Posted April 15, 2014 Posted April 15, 2014 +1 Gig.. And, I don't think Windows will ask to overwrite the files. They have different extensions. I had, at some point, a batch script to remove any flv files that have the same file name as an mp4 file. Wish I could remember where I put that... Or someone remember what post it was?? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
xHyperSteve Posted April 15, 2014 Author Posted April 15, 2014 rfancella! That would be a great thing if you could find that batch file. Let me know! Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
xHyperSteve Posted April 15, 2014 Author Posted April 15, 2014 Hey guys, I've spent so many hours today on setup! Things are falling into place now, and I've learned a ton. I am updating emulators that will not work with the newer modules. After I get everything running in HLHQ, I will go through and setup player 1 and 2 xbox360 pads for all systems. Which should be fun....lol. Here is my latest problem, some systems are giving me "Parsing Errors" telling me that some xml's are not well formed. How can I fix the problem? Are there databases that I can get off the ftp? Would do you recommend? Continually, I was trying to set up zinc, but but I got an error that said the roms are no longer numbered, or something to that effect? Does zinc use a normal naming system now? Thanks a bunch Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
gigapig Posted April 15, 2014 Posted April 15, 2014 Here is my latest problem, some systems are giving me "Parsing Errors" telling me that some xml's are not well formed. How can I fix the problem? Are there databases that I can get off the ftp? Would do you recommend? Which xml's are you referring to? Did you get them via Hypersync? I did here recently that some were showing up corrupt, but would hope that was fixed, if it happened at all. You can try Hyperlist but that should have the same as Hypersync. If you created you own then you will need to use Don's Hypertools, those older xml generators aren't really compatible any more. www.hyperspin-fe.com/forum/showthread.php?25540-Don-s-HyperSpin-Tools-4-3-Beta-Significant-ROM-renamer-and-XML-generation-updates I use 360 pads, one of which is modified in my control panel. Most are set up in the emulator the rest in xpadder. I recently found out, for some of those set in the emu (example SSF) you then need a blank profile for xpadder, otherwise strange things can happen. Strange noises in the attic, icey chills, characters spinning madly, hitting yourself over the head with game pad. It's all true
xHyperSteve Posted April 15, 2014 Author Posted April 15, 2014 Nice, I'll try and re-sync or go the old don's tools route. I have xpadder set in manner that does not affect play. I try to set all controls via emu not using xpadder. I only use xpadder to navigate hyperspin menus. So hopefully no "noises in the attic" Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
rfancella Posted April 15, 2014 Posted April 15, 2014 rfancella! That would be a great thing if you could find that batch file. Let me know! The thread the Gigapig posted has two in it. One as just a command and the other, by Pole, that is a batch file. http://www.hyperspin-fe.com/forum/showthread.php?33464-Transition-from-old-to-new&p=312790&viewfull=1#post312790 Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
xHyperSteve Posted April 15, 2014 Author Posted April 15, 2014 Okay all, the newest errors are" Your system name is: Arcadia 2001 and is not supported by this module Mess" I am trying to fully setup up Arcadia 2001, Channel F, etc. I am have downloaded the correct xml from hyperlist which have their full names i.e. "Emerson Arcadia 2001" and placed them in my "Arcadia 2001" database folder but this hasn't helped. Do I need to rename those folders or modify the MESS module? What is the process I need to use for these types of errors with any system? Thanks Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
rfancella Posted April 15, 2014 Posted April 15, 2014 Okay all, the newest errors are" Your system name is: Arcadia 2001 and is not supported by this module Mess" I am trying to fully setup up Arcadia 2001, Channel F, etc. I am have downloaded the correct xml from hyperlist which have their full names i.e. "Emerson Arcadia 2001" and placed them in my "Arcadia 2001" database folder but this hasn't helped. Do I need to rename those folders or modify the MESS module? What is the process I need to use for these types of errors with any system? Thanks That system should be called "Emerson Arcadia 2001". To find the official names, navigate to: ...\HyperSpin\HyperLaunch\HyperLaunchHQ\Media\Icons There you will find all the icons HLHQ uses and the associated "official" names. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
xHyperSteve Posted April 15, 2014 Author Posted April 15, 2014 Now I know where those are, do I need to rename them? Do I need to rename my database file? What do I rename or change to remedy the problem? Thanks Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
gigapig Posted April 15, 2014 Posted April 15, 2014 You answered your own question earlier . You name then the same as whats in the icons folder. The database should match the icons, if it doesn't rename the db.
rfancella Posted April 15, 2014 Posted April 15, 2014 Now I know where those are, do I need to rename them? Do I need to rename my database file? What do I rename or change to remedy the problem?Thanks See below: You answered your own question earlier . You name then the same as whats in the icons folder. Thanks Gig for the help for sure!!! You can rename the system easily from HyperLaunchHQ. Select the system on the left side. Click the icon at the top left that says, "Rename the Selected System". Put in the new name and hit go! It will rename the database files, folders and all. Hope this helps, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
xHyperSteve Posted April 15, 2014 Author Posted April 15, 2014 Nice! Now I am getting an error that Sega SG1000 supported by fusion module. Also, I have to rename all my zinc files because the numbered roms is not working?! toughts I'm still making progress though, one more solid days work on this and I should have all the kinks worked out so I can back up and start setting up xbox360 pads. ...I'm going to go see captain america right now though! lol thanks for our help homies! Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
xHyperSteve Posted April 15, 2014 Author Posted April 15, 2014 big thanks to rfancella and giga, the rename systems deal worked like a charm on a couple of systems! Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
gigapig Posted April 15, 2014 Posted April 15, 2014 See below:Thanks Gig for the help for sure!!! You can rename the system easily from HyperLaunchHQ. Select the system on the left side. Click the icon at the top left that says, "Rename the Selected System". Put in the new name and hit go! It will rename the database files, folders and all. Hope this helps, Ron Thanks Ron, I'm still learning, I did not know that. Funny the stuff you miss when your set in your ways and it's staring you in the face.
xHyperSteve Posted April 15, 2014 Author Posted April 15, 2014 Already I have every system named properly! Things are coming along! Now... How do I settle problem of Zinc? I have the numbered Romset, do I need to rename every file to their proper short hand name in order for this emulator to work? It has given me nothing but problems the past hour. The error says it does not "recognize the number 22.zip" or any other numbered rom for whatever reason. Thoughts? Is there a good spot on the ftp that has renamer for these roms? cheers Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
