jfp Posted March 15, 2017 Posted March 15, 2017 Struggled for about a day looking for apps to do this,my jamma uses a few hard coded keys like F2,5,6,cntr etc.. messes up some emus and pc games Went the RL route in the end Here are a few helpful links http://www.keyboardtester.com/tester.html https://www.autohotkey.com/docs/KeyList.htm you need to create and edit Rocketlauncher\Lib\User Functions\"Systemname"\"Gamename.ahk" I'll give you Kodi.ahk in Rocketlauncher\Lib\User Functions\Kodi\Kodi.ahk as an example for my setup Kodi.ahk
jfp Posted March 15, 2017 Author Posted March 15, 2017 Unfortunately some games don't play nice with this method like BIT.TRIP RUNNER any other methods?? apart from sharp keys
Metalzoic Posted March 15, 2017 Posted March 15, 2017 Why do it as user functions? RocketLauncher has per game AHK key remapping built right in. Just select your system on the left, go to the key mapper tab, choose a new game (or system etc...) manually type your AHK key remaps below, test them using the test button and save them. Sent from my SM-G935V
jfp Posted March 15, 2017 Author Posted March 15, 2017 ahh i knew it was there somewhere anyway im still trying to get bitrunner to work :/ trying ppjoy and x360e but nothing works
jfp Posted March 17, 2017 Author Posted March 17, 2017 http://headsoft.com.au/index.php?category=vjoy got bittrip runner and sv4 setup on my jamma using vjoy and x360ce
Metalzoic Posted March 18, 2017 Posted March 18, 2017 On 3/17/2017 at 7:47 PM, jfp said: http://headsoft.com.au/index.php?category=vjoy got bittrip runner and sv4 setup on my jamma using vjoy and x360ce Expand Nice. So you are using a straight Jamma cab wiring harness for your control panel? How does it tie into your PC? Some sort of multi-pin connector or iPac type board?
Metalzoic Posted March 18, 2017 Posted March 18, 2017 Ah, forgot to mention that VJoy can work great with some things but cause problems with others. For example a bunch of PC games will flip the **** out if you try to play them with the VJoy drivers enabled, the AAE emulator will crash if you have VJoy enabled etc... But other things won't work at all without it (MKX or Injustice for example). So I set up an AHK script to enable the VJoy drivers when you launch a game and then disable them again when you exit a game.
jfp Posted March 20, 2017 Author Posted March 20, 2017 On 3/18/2017 at 1:51 AM, Metalzoic said: Ah, forgot to mention that VJoy can work great with some things but cause problems with others. For example a bunch of PC games will flip the **** out if you try to play them with the VJoy drivers enabled, the AAE emulator will crash if you have VJoy enabled etc... But other things won't work at all without it (MKX or Injustice for example). So I set up an AHK script to enable the VJoy drivers when you launch a game and then disable them again when you exit a game. Expand Could you upload that script please, i've already encountered this problem and it's very annoying.
Metalzoic Posted March 21, 2017 Posted March 21, 2017 I already have it here in this post/thread below. You should be able to tweak that to work with whatever you need it to.
jfp Posted March 22, 2017 Author Posted March 22, 2017 Thank you, Ran it through per game userfunctions since some steam games don't start from .exe
