Kat5200 Error
Warfare
How do I fix this error? I want to keep my games zipped and I there is a option in Rocket Launcher to use 7z to Unzip then Rezip the game when done playing.
I'm at work and can't check but you'll find the 7z toggle in RLUI in one of that system's settings or general settings tab. I believe the toggle is in the same place as where you define your 7z executable's location. Be careful though, some emulators (eg. VisualBoyAdvance) use the location where the rom was loaded from as the save file / save state location. RLUI's 7z option eventually empties the extraction folder, which can cost you your save files. I remember making a post about it way back but I'd recommend double checking where your saves end up after you've turned 7z support on to see if it'll be an issue.
Yeah it's under the Settings tab and then Main Settings.
24 minutes ago, Avar said:
@gigapig
I just noticed after all this time that your logo pig is drinking a Corona. This pleases me.
Lol, it pleases me too and doubly so if I had a cold one to hand.
Ok, That worked, plus ran into problem were I didn't have BIOS file so, I got that and I am getting this error, How do I fix?
On 4/28/2017 at 9:29 AM, Warfare said:
Im Getting a New Error from the Emulator that says "Error loading ROM Image" but when I load it manually it works.
Any Answers?
17 hours ago, gigapig said:
Did you check your roms were correct as agent47 suggested?
Perhaps post your RL log preferably via pastebin
I enabled what agent47 said to but I still get the error, are you sure its the RL log because its from the emulator that I get this error message.
If you set this system up in RL then we will see what RL is sending to the emulator and see if anything is wrong.
If you asked these questions at the RL forum they would insist on you posting you log in your very first post.
Sorry for questioning you, I was just asking so, it would be faster to get the answer. Here is my Rl log on PasteBin: https://pastebin.com/wPANcUu6. Thanks For Replying and Getting back to me quickly.:thanks:
I've had a chance to look over you log and it looks OK, the one thing in it which is odd is that it does not show the game extension once extracted.
The extension should be .a52 so you may want to check the rom as that would explain the error you get from the emulator. I got the same error when starting Kat5200 but it works fine when run through RL.
I found out that there is a new version of the emulator, not sure if it works with RL yet, can't see why not.
http://kat5200.jillybunch.com
@gigapig @agent47
Thanks Guys! I Did as you said gigapig and did a fresh install, it wasnt working but atleast i could reset everything and had the lastest version, then I did as agent47 said to do but still nothing, I then went inside the 7z and found the roms were .bin (like you said gigapig there not .a52) so, I went and looked at the extensions the Emulator supports in Global  and .bin wasn't listed, so I added it and it worked! Seems like the error was that and now looking at the error message I was getting it makes sense now. Thanks Everyone that helped me!
:thanks:
