Wii Sensor Bar Question
BlueGoblin
Will a Wii sensor bar work fine if i have it mounted inside the arcade machine? it would be right up against the upper marquee plastic - less than a 1/4 inch thick but inside of the arcade machine.
The sensor bar consists of leds that emit infrared light. You can use the camera of your smartphone to see how badly the intensity of the light is reduced. Personally I think it will work fine because of the lights wave length.
