pappabees Posted April 28, 2017 Posted April 28, 2017 Hi all, I am trying to make Hyperspin main menu work with my XBox controller. All the games work fine and even HyperHQ sees it and configures it correctly when I set it up there. Lets me map keys where ever I want to finds the ID, etc. Yet when I run hyperlaunch it doesn't see the joystick. If I look in the log file I do see the following 05:38:25 PM | HyperSpin Started 05:38:25 PM | Going windowed mode 05:38:25 PM | Checking for updates 05:38:25 PM | Update Check Complete 05:38:25 PM | Startup program unavailable 05:38:25 PM | Playing intro video 05:38:28 PM | Error intializing joysticks 05:38:28 PM | Menu Mode is multi 05:38:28 PM | Loading Main Menu.xml 05:38:28 PM | Main Menu.xml successfully loaded 05:38:29 PM | Main Menu wheel loaded successfully 05:39:06 PM | Exit program unavailable 05:39:06 PM | Quiting Hyperspin 05:39:06 PM | Bye! seems like for some reason the joystick isn't initializing anybody seen this. The joystick works in games, etc just not within the Frontend.
Aorin Posted April 28, 2017 Posted April 28, 2017 12 hours ago, pappabees said: Hi all, I am trying to make Hyperspin main menu work with my XBox controller. All the games work fine and even HyperHQ sees it and configures it correctly when I set it up there. Lets me map keys where ever I want to finds the ID, etc. Yet when I run hyperlaunch it doesn't see the joystick. If I look in the log file I do see the following 05:38:25 PM | HyperSpin Started 05:38:25 PM | Going windowed mode 05:38:25 PM | Checking for updates 05:38:25 PM | Update Check Complete 05:38:25 PM | Startup program unavailable 05:38:25 PM | Playing intro video 05:38:28 PM | Error intializing joysticks 05:38:28 PM | Menu Mode is multi 05:38:28 PM | Loading Main Menu.xml 05:38:28 PM | Main Menu.xml successfully loaded 05:38:29 PM | Main Menu wheel loaded successfully 05:39:06 PM | Exit program unavailable 05:39:06 PM | Quiting Hyperspin 05:39:06 PM | Bye! seems like for some reason the joystick isn't initializing anybody seen this. The joystick works in games, etc just not within the Frontend. You should use this startup script instead. Aorin
