VP Newbie - cabinet build - Help Needed
sgoodbar
Thought I would post to the forum to get some advice from you guys.  very impressed with the builds I've found online and I'm a huge Hyperspin fan so this is the place to be.  I recently restored a Dynamo HS-5 arcade cabinet and have it up and running with Hyperspin and Mame.  I'm extremely happy with this thing and my kids and I spend time occasionally revisiting my childhood.  This build gave me experience with setting up the frontend and software, wiring up the USB controller, and other pieces that went into making this boot seamlessly into the front end.
Now it's time for the next project.  I've been on a hunt for a budget pinball project but since there's nothing in my price range, I'd like to give building a virtual pinball machine a shot.
I'm going to attempt to find a trashed widebody pinball cabinet, but may end up building something from scratch.  I'll look for a 46" and 32" LCD, but just like I have an original arcade CRT in my arcade build, I want this VP build to feel as realistic as possible and are looking for an actual Dot Matrix Display.  Best recommendation for DMD?  Are there any high-resolution artwork file resources out there for pinball art?  For example if I build a widebody, I would like to use the STNG artwork (this was a favorite of mine back in the day).  Anyone have some words of wisdom for me on getting started?
>Best LED TV for playfield?  Someone said 1:1 pixel mapping is a must, but what is that and is this true?
>Best DMD - ease of install and integration?
>Best method and parts required for force feedback?
>HQ Art Resources?
>Finally any links to useful tutorials would be much appreciated.
I'd love links to see your builds!  Thanks
welcome to the forum,  and sorry to tell you but this site does not have many active members with pinball cabinets.
I suggest you look into the multiple virtual pinball forums for help.  with that being said.
Quote
cant help you here,  get what you can afford
Quote
the best DMD is a DYK  its called Pin2DMD
it uses a $25 dollar microcontorller and a pair of RGB pannels
you can read all bout it here
http://vpuniverse.com/forums/forum/132-pin2dmd/
their are commercial versions of this but the cost will be 3X of what you would spend if you go the DYK.
Quote
again their are multiple commercial options for you but the best option is to use a DYK
the best option is the DYK with the  $20 KL25Z board
http://vpuniverse.com/forums/topic/2290-kl25z-based-virtual-pinball-allinone-controller-pinscape-controller/
or go directly to the site
https://developer.mbed.org/users/mjr/code/Pinscape_Controller/
You can't connect High current/voltage devices to the KL25Z  board.  You will need to purchase or make
your own expansion boards (all the schematics can be found in the site)
