propdept Posted June 11, 2017 Posted June 11, 2017 This is something I just don't understand, my IDEA of a "No-Nag" screen is that 1 I don't have to sorry about that ".....If you are not legally the owner of this rom" screen, doesn't appear. That I have to click OK or wiggle the joystick left and right to get past it. 2 The "........the sound on this game is not accurate" please click OK or wiggle the joystick Frankly I want those screens to just GO AWAY and when I click on the game MAME boots right strait to the game. But everytime I download a NO NAG MAME I get cursed with those screens! What am I missing or not understanding here?
rastan Posted June 12, 2017 Posted June 12, 2017 20 hours ago, propdept said: This is something I just don't understand, my IDEA of a "No-Nag" screen is that 1 I don't have to sorry about that ".....If you are not legally the owner of this rom" screen, doesn't appear. That I have to click OK or wiggle the joystick left and right to get past it. 2 The "........the sound on this game is not accurate" please click OK or wiggle the joystick Frankly I want those screens to just GO AWAY and when I click on the game MAME boots right strait to the game. But everytime I download a NO NAG MAME I get cursed with those screens! What am I missing or not understanding here? If it's no nag you shouldn't see any of that... where are you getting your no nags from?
propdept Posted June 12, 2017 Author Posted June 12, 2017 I am getting them from the hyper spin website. Let me also say that I don't want to see the black screen that comes up with the game name that you have to click any key to go to the next screen which will either start the game or you get another screen telling you about the sound is not accurate or not correct
rastan Posted June 16, 2017 Posted June 16, 2017 On 6/12/2017 at 7:46 PM, propdept said: I am getting them from the hyper spin website. Let me also say that I don't want to see the black screen that comes up with the game name that you have to click any key to go to the next screen which will either start the game or you get another screen telling you about the sound is not accurate or not correct that's strange.... I haven't updated my mame in a while but my no nag is just that.. when I launch a game it goes straight into the rom.. no need to press any button or move joystick.
propdept Posted June 18, 2017 Author Posted June 18, 2017 Well I have some games that when you launch them, you get this nag screen. the Sound Is not Acurate or the Rom didn't load properly.......I want to avoid that screen too Just load strait to the game....
propdept Posted June 28, 2017 Author Posted June 28, 2017 Like I said before I don't like the fact that something pops up telling me the sound is not accurate the video is not accurate or there was a problem with the CHD dump or ROM dump. Now I know that I'm not using True Mame. I am using Mameuifx 104 I know it's outdated I know that that program is no longer updated but it absolutely gets right past all the gobbledygook and straight to the game
artman999999 Posted June 29, 2017 Posted June 29, 2017 Your ini isn't set up properly. Using the ini provided from the original MAME download does not have the no-nag option. If you have no idea what I'm talking about, install the no-nag version. Then generate a mame.ini by bringing up a command line in the MAME root directory and running "mame64 -cc". The mame.ini will then be created in the root directory (txt file). You'll see the no-nag option somewhere near the middle. I've attached one from MAME v172 for reference. DON'T USE THIS INI FILE IN YOUR BUILD AS IT PROBABLY WON'T MATCH YOUR VERSION OR NO-NAG COMPILE DIFF. IT'S JUST FOR EXAMPLE. mame.ini
propdept Posted June 29, 2017 Author Posted June 29, 2017 I downloaded the Mame file and I also downloaded the no nag option and put that into my Mame directory if I understand what you are telling me is in the Mame. Ini file halfway through the text document is a no nag option that has not been set is this correct? Will this option stop the bothersome your sound is not configured or accurate or your video is not accurate or the ROM dump is not correct from popping up on my screen I do not want them to pop up at all
ci2own Posted June 29, 2017 Posted June 29, 2017 You can also try the insertmorecoins web page one. I use that one without any problems.
propdept Posted June 30, 2017 Author Posted June 30, 2017 # disable_hiscore_patch 0 disable_nagscreen_patch 0 disable_loading_patch 0 artman999999. Is this what you referenced in your previous post? I checked my mame INI and there is no mention of the above. FYI the version of mame I am using is mame0184b_64bit and I got the no nag from hyper spin website (the no nag Was on their third party section and now I cant find it..... OK CAN any one recommend a NO NAG Mame version 179 or higher that I don't get bothered by *There are known problems with this machine. The Sound Emulation isn't 100% accurate Press any Key to Continue * There are known problems with this machine. One or more ROMS/CHD for this machine have not been correctly dumped Press any Key to Continue * There are known problems with this machine. The video emulation isn't 100% accurate Press any Key to Continue To give you example of games I get these errors on, Astro Blaster, Air wolf, Buck Rodgers, Circus, Galaga, Operation Wolf, Pleiades, Omega Race just to name a few.... OK CAN any one recommend a NO NAG Mame version 179 or higher that I don't get bothered by the above errors? Mameuifx 104, my current MAME, will no longer work with what I want to do and interface properly with Rocket Launcher
ci2own Posted July 29, 2017 Posted July 29, 2017 On 30/6/2017 at 2:22 AM, propdept said: # disable_hiscore_patch 0 disable_nagscreen_patch 0 disable_loading_patch 0 artman999999. Is this what you referenced in your previous post? I checked my mame INI and there is no mention of the above. FYI the version of mame I am using is mame0184b_64bit and I got the no nag from hyper spin website (the no nag Was on their third party section and now I cant find it..... OK CAN any one recommend a NO NAG Mame version 179 or higher that I don't get bothered by *There are known problems with this machine. The Sound Emulation isn't 100% accurate Press any Key to Continue * There are known problems with this machine. One or more ROMS/CHD for this machine have not been correctly dumped Press any Key to Continue * There are known problems with this machine. The video emulation isn't 100% accurate Press any Key to Continue To give you example of games I get these errors on, Astro Blaster, Air wolf, Buck Rodgers, Circus, Galaga, Operation Wolf, Pleiades, Omega Race just to name a few.... OK CAN any one recommend a NO NAG Mame version 179 or higher that I don't get bothered by the above errors? Mameuifx 104, my current MAME, will no longer work with what I want to do and interface properly with Rocket Launcher I told you: can use the insertmorecoins.es one http://insertmorecoins.es/mame-mameui-0-188-32-64-bits-no-nag-including-mess/
