Theme problems
jevansoh
I'm using a Wii theme I found on YouTube and am having an odd problem.  All my other themes for all other systems work fine, but this one, for whatever reason, only works one time per session.
What I mean is when I'm on the main wheel, if I select Wii, the theme will display the video and show a disc loading animation with the disc going into the slot of a Wii machine.
As soon as I scroll to a different selection, though, it no longer works.  No video shows and it's just a black box and no disc loading animation shows.  I have to exit the wheel and go back in to it for it to work again, and again, it will only work one time.
I don't have a clue as to what could cause this or where to begin looking.
Suggestions would be most appreciated.
Thanks,
--J
Thanks,
--J
Have you checked your HS settings (HyperHQ) to make sure the y are correct? Make sure reload backgrounds is checked on etc...?
That fixed it!  Thank you!
The weird thing is that option isn't checked on any of my other themes and they all work fine.  Wonder why they all work fine and this one needed that checked to work?
Thanks again!
--J
