hyperspin rlauncher
bigcam
can you tell me how to bypass rlauncher ini configs and just use the emulator configs i have my emus all configured but when i launch them through rl it changes the configs in demul and model 2 and 3
I'll reply here instead of YT.
All I can suggest is to set your emulator ini's to "read only" so they can't be modified as long as doing so does not throw up an error. Although I've not know ini files to be modified for Sega Model 1& 2.
For Demul it can be a good idea to add the settings to RocketLauncher but you should read the module notes and back up your files.
This may be of use if you use a 360 controller for Demul.
