abysslord Posted April 25, 2014 Posted April 25, 2014 I've been trying all day to get PPSSPP to run in my hyperspin build. I get an error message that say no default emulator was found. Am i completely oblivious to something i did wrong or is it not possible? I have gotten many others to work except dis one for some reason. Any help would be greatly appreciated!
SIMPLYAUSTIN Posted April 26, 2014 Posted April 26, 2014 Have you set it up in global settings first? Simply Austin's YouTube
abysslord Posted April 29, 2014 Author Posted April 29, 2014 i havent tried that yet. What exactly do you think i should do? I have used the same methods from past systems i added. I just don't know what exactly to do. Thanks for any help!
gigapig Posted April 29, 2014 Posted April 29, 2014 What emulator are you using and please post your logs. Cheers. I think Austin is right, you've missed the first step of setting up in HLHQ.
SIMPLYAUSTIN Posted April 29, 2014 Posted April 29, 2014 Yes its not hard. You just click on the EMULATORS on the top tab. GLOBAL on the left box. Scroll down and find PPSSPP, click it and give it what it wants. Its only a few clicks, off the top of my head I think it only needs the root to the emu you have installed, as in the EXE of the emulator. The rest should be there anyways but just check what extensions you have as I think I had to add 7z as I had them all zipped up small. Once thats done it "should" be fine hehehe (if that is indeed your problem) Simply Austin's YouTube
abysslord Posted May 1, 2014 Author Posted May 1, 2014 Thanks for the help so far guys! I was wondering, do i need to create a wheel tab first in HyperHQ first? i noticed that when i enter HLHQ that there is no PSP (of course) in the side left bar. And if i must create it (which i have before just testing methods) i notice that no modules show up at all in the module path once i create the emulator settings for the emulator.
abysslord Posted May 1, 2014 Author Posted May 1, 2014 SO where I am at so far is when I run Hyperspin and choose a game in the PSP tab, i get the "no default emulator" message. It's weird because when i go to choose the default emulator for PSP in HLHQ i get no emulator to choose from. Is my brain in another place? lol Sorry to bug you uys with noob questions, and oh yes i will be donating very soon
abysslord Posted May 1, 2014 Author Posted May 1, 2014 well it seems i am missing or can't find the .ini file
gigapig Posted May 1, 2014 Posted May 1, 2014 Yes you will need to set up a wheel in Hyper HQ (which I think you have probably done now) and it will need to be named "Sony PSP" Can you confirm that's all done.
abysslord Posted May 2, 2014 Author Posted May 2, 2014 Success! Thank you guys. I found out that I was naming the wheel wrong with "PSP" and not "Sony PSP". I now have it successfully running! Just a reminder to everyone that has this problem to be sure to check your spelling and notations. Thanks a million guys!
hobbit1966 Posted July 23, 2014 Posted July 23, 2014 Hi, I need help. I am trying to set up PPSSPP to work with hyperspin. I tried the steps outlined here but it is still not working. I got the "Sony PSP is an invalid System Name or PPSSPPWindows.exe isnt supported yet". The emulator works in Hyperlaunch.exe inside the hyperlaunch folder. Outside of hyperspin works as well. Any help is really appreciated. Thanks.
gigapig Posted July 23, 2014 Posted July 23, 2014 Hi, I need help. I am trying to set up PPSSPP to work with hyperspin. I tried the steps outlined here but it is still not working. I got the "Sony PSP is an invalid System Name or PPSSPPWindows.exe isnt supported yet". The emulator works in Hyperlaunch.exe inside the hyperlaunch folder. Outside of hyperspin works as well. Any help is really appreciated. Thanks. I never had this set up before until now, it took around 10 minutes. I downloaded the latest version which now has a x64 version. My system name is Sony PSP. That is the only option you have, sony Psp won't work it has to be Sony PSP. Then I had to move the ppsspp.ini into Emulators\Sony PSP\PPSSPP\memstick\PSP\SYSTEM After that I was surprised to see it start up, bezel and all, I ran the emu once but did not mess with the settings. Is your setup, up to date via GIT? And please post your Hyperlaunch log, if your not sure how to do that read the sticky on the main menu forum. And welcome to the forum young Hobbit.
hobbit1966 Posted July 23, 2014 Posted July 23, 2014 Thanks gigapig for a quick reply. I will try it tonight and report back.
hobbit1966 Posted July 24, 2014 Posted July 24, 2014 Hi gigapig, I tried your advice last night and still have the same message "Sony PSP is an invalid System Name or PPSSP.exe isnt supported yet". Here is my hyperlaunch log: [code] 16:47:57:166 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9 16:47:57:166 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: E:\Hyperspin\Hyperlaunch OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 16:47:57:166 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 16:47:57:166 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\HyperLaunch.exe exists 16:47:57:167 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.0.9 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 899072 bytes Created: 7/5/2014 - 11:02:02 AM Modified: 6/15/2014 - 7:44:59 PM 16:47:57:167 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Module Extensions\gdip.ahk exists 16:47:57:171 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 16:47:57:172 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 7/5/2014 - 11:02:30 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:172 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Module Extensions\RIni.ahk exists 16:47:57:174 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 16:47:57:174 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 7/5/2014 - 11:02:31 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:174 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Module Extensions\CLR.ahk exists 16:47:57:175 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 16:47:57:175 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 7/5/2014 - 11:02:30 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:175 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Module Extensions\COM.ahk exists 16:47:57:176 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 16:47:57:176 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 7/5/2014 - 11:02:30 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:176 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Module Extensions\JSON.ahk exists 16:47:57:177 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 16:47:57:177 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 7/5/2014 - 11:02:31 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:177 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Fade Init.ahk exists 16:47:57:178 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:178 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1145 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:178 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\HyperPause Init.ahk exists 16:47:57:178 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:179 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:179 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Keymapper Init.ahk exists 16:47:57:179 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:179 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:180 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\MultiGame Init.ahk exists 16:47:57:180 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:180 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:180 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Statistics Init.ahk exists 16:47:57:181 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:181 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:181 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Fade.ahk exists 16:47:57:182 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:182 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 25516 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:182 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\HyperPause.ahk exists 16:47:57:188 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:189 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 360180 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:189 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Keymapper.ahk exists 16:47:57:190 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:190 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 30775 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:190 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\MultiGame.ahk exists 16:47:57:191 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:191 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36816 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:191 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Bezel.ahk exists 16:47:57:194 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:194 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 83008 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:194 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Statistics.ahk exists 16:47:57:195 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:195 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26153 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:195 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Rom Mapping Launch Menu.ahk exists 16:47:57:197 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:197 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:197 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Shared.ahk exists 16:47:57:199 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:199 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 81966 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:199 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\XHotkey.ahk exists 16:47:57:200 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:200 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28374 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:200 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Lib\Fade Animations.ahk exists 16:47:57:202 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 16:47:57:202 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 49050 bytes Created: 7/5/2014 - 11:02:04 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:57:202 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Databases\Main Menu\Main Menu.xml exists 16:47:57:203 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 265 bytes Created: 7/5/2014 - 8:45:46 AM Modified: 7/24/2014 - 4:32:11 PM 16:47:57:217 | HL | INFO | +16 | Main - HyperLaunch launched directly 16:47:58:534 | HL | INFO | +1310 | Main - HyperLaunch received "Sony PSP" and "Assassins Creed Bloodlines" 16:47:58:543 | HL | INFO | +16 | Main - Assassins Creed Bloodlines is using the default emulator: PPSSPP 16:47:58:543 | HL | INFO | +0 | Main - Checking for a [PPSSPP] section in E:\Hyperspin\Hyperlaunch\Settings\Sony PSP\Emulators.ini 16:47:58:543 | HL | INFO | +0 | Main - Checking for a [PPSSPP] section in E:\Hyperspin\Hyperlaunch\Settings\Global Emulators.ini 16:47:58:544 | HL | INFO | +0 | Main - Found [PPSSPP] in E:\Hyperspin\Hyperlaunch\Settings\Global Emulators.ini 16:47:58:544 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Modules\PPSSPP\PPSSPP.ahk exists 16:47:58:545 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1814 bytes Created: 7/5/2014 - 11:02:33 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:58:546 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 16:47:58:546 | HL | INFO | +0 | Main - Assassins Creed Bloodlines will use module: E:\Hyperspin\Hyperlaunch\Modules\PPSSPP\PPSSPP.ahk 16:47:58:558 | HL | INFO | +15 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks. 16:47:58:560 | HL | INFO | +0 | Main - INI Keys read 16:47:58:560 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Module Extensions\7z.exe exists 16:47:58:561 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 7/5/2014 - 11:02:30 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:58:561 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\Module Extensions\7z.dll exists 16:47:58:562 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 7/5/2014 - 11:02:30 AM Modified: 7/24/2014 - 3:48:43 AM 16:47:58:562 | HL | INFO | +0 | CheckPaths - Started 16:47:58:562 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines.7z 16:47:58:562 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines\Assassins Creed Bloodlines.7z 16:47:58:562 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines\*.7z 16:47:58:562 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines.zip 16:47:58:562 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines\Assassins Creed Bloodlines.zip 16:47:58:563 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines\*.zip 16:47:58:563 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines.cue 16:47:58:563 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines\Assassins Creed Bloodlines.cue 16:47:58:563 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines\*.cue 16:47:58:563 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines.iso 16:47:58:563 | HL | INFO | +0 | CheckPaths - Found rom: E:\Hyperspin\Emulators\PPSSPP\rom\Assassins Creed Bloodlines.iso 16:47:58:564 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Emulators\PPSSPP\PPSSPP.exe exists 16:47:58:564 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription PPSSPP FileVersion 0, 9, 9, 0 InternalName PPSSPPEmu LegalCopyright Copyright (C) 2006-2013 by Henrik Rydgård OriginalFilename PPSSPP.exe ProductName PPSSPP ProductVersion 0, 9, 9, 0 CompanyName Henrik Rydgård LegalTrademarks All product names are trademarks of their respective owners. File Size: 7556608 bytes Created: 7/21/2014 - 8:20:17 PM Modified: 7/22/2014 - 9:46:10 AM 16:47:58:564 | HL | INFO | +0 | CheckPaths - Ended 16:47:58:565 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 0 frontendPID = 0 frontendPath = E:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = E: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s emuFullPath = E:\Hyperspin\Emulators\PPSSPP\PPSSPP.exe emuPath = E:\Hyperspin\Emulators\PPSSPP emuName = PPSSPP emuExt = exe romPath = E:\Hyperspin\Emulators\PPSSPP\rom romPathFromIni = E:\Hyperspin\Emulators\PPSSPP\rom romExtension = .iso romExtensionOrig = .iso romExtensions = 7z|zip|cue|iso executable = PPSSPP.exe systemName = Sony PSP dbName = Assassins Creed Bloodlines romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true logFile = E:\Hyperspin\Hyperlaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1080 dtEnabled = true dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe dtUseSCSI = true dtAddDrive = false emuIdleShutdown = 0 hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = E:\Hyperspin\Hyperlaunch\Media\Fade HLDataPath = E:\Hyperspin\Hyperlaunch\Data HLMediaPath = E:\Hyperspin\Hyperlaunch\Media HLErrSoundPath = E:\Hyperspin\Hyperlaunch\Media\Sounds\Error modulesPath = E:\Hyperspin\Hyperlaunch\Modules moduleFullName = E:\Hyperspin\Hyperlaunch\Modules\PPSSPP\PPSSPP.ahk moduleName = PPSSPP modulePath = E:\Hyperspin\Hyperlaunch\Modules\PPSSPP moduleExtension = ahk moduleExtensionsPath = E:\Hyperspin\Hyperlaunch\Module Extensions libPath = E:\Hyperspin\Hyperlaunch\Lib 7zEnabled = false 7zPath = E:\Hyperspin\Hyperlaunch\Module Extensions\7z.exe 7zDllPath = E:\Hyperspin\Hyperlaunch\Module Extensions\7z.dll 7zExtractPath = E:\Hyperspin\Emulators\PCSX2 1.0.0 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 0 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = E:\Hyperspin\Hyperlaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapper = xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = E:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = E:\Hyperspin\Hyperlaunch\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = E:\Hyperspin\Hyperlaunch\Profiles\\HyperSpin defaultProfile = E:\Hyperspin\Hyperlaunch\Profiles\\_Default systemProfile = E:\Hyperspin\Hyperlaunch\Profiles\\Sony PSP xPadderSystemProfile = E:\Hyperspin\Hyperlaunch\Profiles\\Sony PSP\_Default emuProfile = E:\Hyperspin\Hyperlaunch\Profiles\\Sony PSP\PPSSPP romProfile = E:\Hyperspin\Hyperlaunch\Profiles\\Sony PSP\Assassins Creed Bloodlines blankProfile = E:\Hyperspin\Hyperlaunch\Profiles\\blank HyperLaunchProfile = E:\Hyperspin\Hyperlaunch\Profiles\\HyperLaunch bezelEnabled = false statisticsEnabled = true 16:47:58:565 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 16:47:58:565 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 16:47:58:566 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 16:47:58:566 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 285 16:47:58:566 | HL | INFO | +0 | BuildScript - Module: MEmu = PPSSPP MEmuV = v0.9.5 MURL = http://www.ppsspp.org/ MAuthor = djvj MVersion = 2.0.2 MCRC = B3ADF265 iCRC = 86DE2C7A MID = 635038268916444338 MSystem = "Sony PSP" ;---------------------------------------------------------------------------- ; Notes: ; CLI options: http://forums.ppsspp.org/showthread.php?tid=339&pid=17117#pid17117 ; Compatibility List: http://forums.ppsspp.org/showthread.php?tid=1473 ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) bezelSleep := IniReadCheck(settingsFile, "Settings", "bezelSleep","1500",,1) ; in miliseconds, if you are using the bezel view and your screen does not fit correctly in the bezel, try to increase this value. BezelStart() 7z(romPath, romName, romExtension, 7zExtractPath) ppssppINI := CheckFile(emuPath . "\memstick\PSP\System\ppsspp.ini") iniRead, currentFullScreen, %ppssppINI%, Graphics, FullScreen ; Setting Fullscreen setting in ini if it doesn't match what user wants above If ( Fullscreen != "true" And currentFullScreen = "True" ) IniWrite, False, %ppssppINI%, Graphics, FullScreen Else If ( Fullscreen = "true" And currentFullScreen = "False" ) IniWrite, True, %ppssppINI%, Graphics, FullScreen Run(executable . " """ . romPath . "\" . romName . romExtension . """", emupath) WinActivate, PPSSPP ahk_class PPSSPPWnd WinWaitActive("PPSSPP ahk_class PPSSPPWnd") If bezelPath Sleep, %bezelSleep% BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("PPSSPP ahk_class PPSSPPWnd") Return 16:47:58:566 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 16:47:58:567 | HL | INFO | +16 | BuildScript - Loaded User Functions.ahk script 16:47:58:567 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 16:47:58:567 | HL | INFO | +0 | Main - Module is built 16:47:58:567 | HL | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Hyperlaunch\AutoHotkey.dll exists 16:47:58:568 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 7/5/2014 - 11:02:01 AM Modified: 7/24/2014 - 3:48:42 AM 16:47:58:569 | HL | INFO | +0 | Main - Running module 16:47:58:569 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 16:48:00:101 | HL | INFO | +1529 | Main - Module ended, exiting HyperLaunch normally 16:48:00:101 | HL | INFO | +0 | ExitScript - Started 16:48:00:106 | HL | DEBUG1 | +0 | ExitScript - Putting HyperSpin.exe back in focus 16:48:00:116 | HL | INFO | +15 | SystemCursor - Restoring mouse cursor 16:48:00:125 | HL | INFO | +0 | ExitScript - Ended [/code] The Emulator.ini inside hyperlaunch is: [ROMS] Default_Emulator=PPSSPP Rom_Path=..\Emulators\PPSSPP\rom The Sony PSP.ini is: [exe info] path=E:\Hyperspin\Emulators\PPSSPP\ rompath=E:\Hyperspin\Emulators\PPSSPP\rom\ userompath=true exe=PPSSPP.exe romextension=iso,cue, bin parameters= searchsubfolders=true pcgame=false winstate=HIDDEN hyperlaunch=true Furthermore, do I need to add a script to the hyperlaunch.ahk inside the hyperspin folder as well? If I do, what is the script? I have successfully added 5 other emulators, but this one is giving me problems. Please help and I can't tell you how grateful I am. p.s. per your advice, I have also updated the system via GIT. Thanks again for your help.
hobbit1966 Posted July 25, 2014 Posted July 25, 2014 Hi gigapig, I've tried it again and it still did not work. Here's the hyperlaunch log for the system. Please take a look and show me the errors. I am still learning. Thanks. 20:08:31:875 | HL | INFO | +N/A | Main - HyperLaunch v3.0.0.9 20:08:31:876 | HL | INFO | +0 | Main - System Specs: HyperLaunch Dir: C:\Hyperspin\Hyperlaunch OS: WIN_7 Architecture: 64-bit (might not be accurate) OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 20:08:31:876 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x y w h 20:08:31:876 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\HyperLaunch.exe exists 20:08:31:876 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.0.9 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 899072 bytes Created: 7/24/2014 - 7:17:02 PM Modified: 6/15/2014 - 7:44:59 PM 20:08:31:877 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\gdip.ahk exists 20:08:31:881 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:08:31:881 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 7/24/2014 - 7:17:19 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:882 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\RIni.ahk exists 20:08:31:883 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 20:08:31:884 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 7/24/2014 - 7:17:19 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:884 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\CLR.ahk exists 20:08:31:885 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:08:31:885 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 7/24/2014 - 7:17:19 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:885 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\COM.ahk exists 20:08:31:886 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:08:31:886 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 7/24/2014 - 7:17:19 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:887 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\JSON.ahk exists 20:08:31:887 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:08:31:887 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 7/24/2014 - 7:17:19 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:888 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Fade Init.ahk exists 20:08:31:888 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:888 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1145 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:888 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\HyperPause Init.ahk exists 20:08:31:889 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:889 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:889 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Keymapper Init.ahk exists 20:08:31:890 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:890 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:890 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\MultiGame Init.ahk exists 20:08:31:890 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:891 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:891 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Statistics Init.ahk exists 20:08:31:891 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:892 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:892 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Fade.ahk exists 20:08:31:893 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:893 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 25516 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:893 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\HyperPause.ahk exists 20:08:31:899 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:900 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 360180 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:900 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Keymapper.ahk exists 20:08:31:901 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:901 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 30775 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:901 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\MultiGame.ahk exists 20:08:31:902 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:903 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36816 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:903 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Bezel.ahk exists 20:08:31:905 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:906 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 83008 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:906 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Statistics.ahk exists 20:08:31:907 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:907 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26153 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:907 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Rom Mapping Launch Menu.ahk exists 20:08:31:908 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:909 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:909 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Shared.ahk exists 20:08:31:911 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:911 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 81966 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:911 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\XHotkey.ahk exists 20:08:31:912 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:912 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28374 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:912 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Lib\Fade Animations.ahk exists 20:08:31:914 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 20:08:31:914 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 49050 bytes Created: 7/24/2014 - 7:17:03 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:31:914 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Databases\Main Menu\Main Menu.xml exists 20:08:31:915 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 65 bytes Created: 7/24/2014 - 7:24:47 PM Modified: 7/24/2014 - 7:26:13 PM 20:08:31:927 | HL | INFO | +0 | Main - HyperLaunch launched directly 20:08:32:868 | HL | INFO | +952 | Main - HyperLaunch received "Sony PSP" and "GI Goe The Rise Of the Cobra" 20:08:32:877 | HL | INFO | +0 | Main - GI Goe The Rise Of the Cobra is using the default emulator: PPSSPP 20:08:32:877 | HL | INFO | +0 | Main - Checking for a [PPSSPP] section in C:\Hyperspin\Hyperlaunch\Settings\Sony PSP\Emulators.ini 20:08:32:878 | HL | INFO | +0 | Main - Checking for a [PPSSPP] section in C:\Hyperspin\Hyperlaunch\Settings\Global Emulators.ini 20:08:32:879 | HL | INFO | +0 | Main - Found [PPSSPP] in C:\Hyperspin\Hyperlaunch\Settings\Global Emulators.ini 20:08:32:879 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Modules\PPSSPP\PPSSPP.ahk exists 20:08:32:880 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1814 bytes Created: 7/24/2014 - 7:17:21 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:32:881 | HL | INFO | +15 | Main - CRC Check - CRC matches, this is an official unedited module. 20:08:32:881 | HL | INFO | +0 | Main - GI Goe The Rise Of the Cobra will use module: C:\Hyperspin\Hyperlaunch\Modules\PPSSPP\PPSSPP.ahk 20:08:32:896 | HL | INFO | +0 | Main - Using standard method with "Rom Extensions" SkipChecks or without any SkipChecks. 20:08:32:897 | HL | INFO | +16 | Main - INI Keys read 20:08:32:897 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\7z.exe exists 20:08:32:898 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 7/24/2014 - 7:17:19 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:32:899 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\7z.dll exists 20:08:32:900 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 7/24/2014 - 7:17:19 PM Modified: 7/24/2014 - 7:16:11 PM 20:08:32:900 | HL | INFO | +0 | CheckPaths - Started 20:08:32:900 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra.7z 20:08:32:900 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra\GI Goe The Rise Of the Cobra.7z 20:08:32:900 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra\*.7z 20:08:32:901 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra.zip 20:08:32:901 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra\GI Goe The Rise Of the Cobra.zip 20:08:32:901 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra\*.zip 20:08:32:901 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra.cue 20:08:32:901 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra\GI Goe The Rise Of the Cobra.cue 20:08:32:902 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by extension: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra\*.cue 20:08:32:902 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra.iso 20:08:32:902 | HL | INFO | +0 | CheckPaths - Found rom: C:\Hyperspin\Emulators\PPSSPP\Rom\GI Goe The Rise Of the Cobra.iso 20:08:32:902 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Emulators\PPSSPP\PPSSPPWindows.exe exists 20:08:32:903 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription PPSSPP FileVersion 0, 0, 9, 8 InternalName PPSSPPEmu LegalCopyright Copyright (C) 2006-2013 by Henrik Rydgård OriginalFilename PPSSPP.exe ProductName PPSSPP ProductVersion 0, 0, 9, 8 CompanyName Henrik Rydgård LegalTrademarks All product names are trademarks of their respective owners. File Size: 7388672 bytes Created: 7/24/2014 - 7:32:32 PM Modified: 3/22/2014 - 2:55:42 PM 20:08:32:903 | HL | INFO | +0 | CheckPaths - Ended 20:08:32:904 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 0 frontendPID = 0 frontendPath = C:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = C: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s emuFullPath = C:\Hyperspin\Emulators\PPSSPP\PPSSPPWindows.exe emuPath = C:\Hyperspin\Emulators\PPSSPP emuName = PPSSPP emuExt = exe romPath = C:\Hyperspin\Emulators\PPSSPP\Rom romPathFromIni = C:\Hyperspin\Emulators\PPSSPP\Rom romExtension = .iso romExtensionOrig = .iso romExtensions = 7z|zip|cue|iso executable = PPSSPPWindows.exe systemName = Sony PSP dbName = GI Goe The Rise Of the Cobra romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true logFile = C:\Hyperspin\Hyperlaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1080 dtEnabled = true dtPath = dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\Hyperspin\Hyperlaunch\Media\Fade HLDataPath = C:\Hyperspin\Hyperlaunch\Data HLMediaPath = C:\Hyperspin\Hyperlaunch\Media HLErrSoundPath = C:\Hyperspin\Hyperlaunch\Media\Sounds\Error modulesPath = C:\Hyperspin\Hyperlaunch\Modules moduleFullName = C:\Hyperspin\Hyperlaunch\Modules\PPSSPP\PPSSPP.ahk moduleName = PPSSPP modulePath = C:\Hyperspin\Hyperlaunch\Modules\PPSSPP moduleExtension = ahk moduleExtensionsPath = C:\Hyperspin\Hyperlaunch\Module Extensions libPath = C:\Hyperspin\Hyperlaunch\Lib 7zEnabled = false 7zPath = C:\Hyperspin\Hyperlaunch\Module Extensions\7z.exe 7zDllPath = C:\Hyperspin\Hyperlaunch\Module Extensions\7z.dll 7zExtractPath = C:\Users\Thuan Tran\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 0 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = false hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = C:\Hyperspin\Hyperlaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapper = xpadderFullPath = C:\Hyperspin\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = C:\Hyperspin\Hyperlaunch\Profiles\ keymapperFrontEndProfileName = HyperSpin keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = C:\Hyperspin\Hyperlaunch\Profiles\\HyperSpin defaultProfile = C:\Hyperspin\Hyperlaunch\Profiles\\_Default systemProfile = C:\Hyperspin\Hyperlaunch\Profiles\\Sony PSP xPadderSystemProfile = C:\Hyperspin\Hyperlaunch\Profiles\\Sony PSP\_Default emuProfile = C:\Hyperspin\Hyperlaunch\Profiles\\Sony PSP\PPSSPP romProfile = C:\Hyperspin\Hyperlaunch\Profiles\\Sony PSP\GI Goe The Rise Of the Cobra blankProfile = C:\Hyperspin\Hyperlaunch\Profiles\\blank HyperLaunchProfile = C:\Hyperspin\Hyperlaunch\Profiles\\HyperLaunch bezelEnabled = false statisticsEnabled = true 20:08:32:904 | HL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 20:08:32:904 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 20:08:32:905 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 20:08:32:905 | HL | DEBUG1 | +0 | BuildScript - Module starts on line: 285 20:08:32:906 | HL | INFO | +0 | BuildScript - Module: MEmu = PPSSPP MEmuV = v0.9.5 MURL = http://www.ppsspp.org/ MAuthor = djvj MVersion = 2.0.2 MCRC = B3ADF265 iCRC = 86DE2C7A MID = 635038268916444338 MSystem = "Sony PSP" ;---------------------------------------------------------------------------- ; Notes: ; CLI options: http://forums.ppsspp.org/showthread.php?tid=339&pid=17117#pid17117 ; Compatibility List: http://forums.ppsspp.org/showthread.php?tid=1473 ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) bezelSleep := IniReadCheck(settingsFile, "Settings", "bezelSleep","1500",,1) ; in miliseconds, if you are using the bezel view and your screen does not fit correctly in the bezel, try to increase this value. BezelStart() 7z(romPath, romName, romExtension, 7zExtractPath) ppssppINI := CheckFile(emuPath . "\memstick\PSP\System\ppsspp.ini") iniRead, currentFullScreen, %ppssppINI%, Graphics, FullScreen ; Setting Fullscreen setting in ini if it doesn't match what user wants above If ( Fullscreen != "true" And currentFullScreen = "True" ) IniWrite, False, %ppssppINI%, Graphics, FullScreen Else If ( Fullscreen = "true" And currentFullScreen = "False" ) IniWrite, True, %ppssppINI%, Graphics, FullScreen Run(executable . " """ . romPath . "\" . romName . romExtension . """", emupath) WinActivate, PPSSPP ahk_class PPSSPPWnd WinWaitActive("PPSSPP ahk_class PPSSPPWnd") If bezelPath Sleep, %bezelSleep% BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("PPSSPP ahk_class PPSSPPWnd") Return 20:08:32:906 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 20:08:32:906 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 20:08:32:906 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 20:08:32:906 | HL | INFO | +0 | Main - Module is built 20:08:32:906 | HL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\AutoHotkey.dll exists 20:08:32:907 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 7/24/2014 - 7:17:02 PM Modified: 7/24/2014 - 7:16:10 PM 20:08:32:908 | HL | INFO | +0 | Main - Running module 20:08:32:908 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 20:08:34:219 | HL | INFO | +1310 | Main - Module ended, exiting HyperLaunch normally 20:08:34:220 | HL | INFO | +0 | ExitScript - Started 20:08:34:224 | HL | DEBUG1 | +16 | ExitScript - Putting HyperSpin.exe back in focus 20:08:34:237 | HL | INFO | +0 | SystemCursor - Restoring mouse cursor 20:08:34:243 | HL | INFO | +16 | ExitScript - Ended [/code] The Sony PSP Emulators.ini is: [ROMS] Default_Emulator=PPSSPP Rom_Path=..\Emulators\PPSSPP\Rom The Settings Sony PSP.ini is [exe info] path=C:\Hyperspin\Emulators\PPSSPP\ rompath=C:\Hyperspin\Emulators\PPSSPP\Rom\ userompath=true exe=PPSSPPWindows.exe romextension=iso,cso parameters= searchsubfolders=true pcgame=false winstate=HIDDEN hyperlaunch=true I truely appreciate your help in this matter.
