Prosystem with Atari 7800
loppydog
Are you using the win32 version or the D2D version? The D2D version does not work with the current module.
As for the Win32 version, I can also get it working fine from my desktop triple monitor setup, but when I try to load through hyperlaunch, it just flashes black and closes (I then have to kill the process).
The weird thing is, when I switch my display to my HDTV only, it loads perfectly fine through hs. I'm guessing the issue has something to do with display resolution.
I'm using win32 ya. Interesting, can u change the resolution on the emulator or in the setting inis so it's automatic? Also how do I config my second joystick so 2 players can play at the same time aka double dragon. This emulator isn't the easiest to use and I have all the official wheels but mame :D
What resolution works for you?
Genius! Defaulted setting to full screen in the emulator and it worked
Now how do I configure this thug for trackball and a 2 player joystick to play double dragon? I can only get it to switch one player stick
  • 10 months later...
hello everyone! I'm not sure if I should have created another topic, but I've fixed the fullscreen color issue using ProSystem 1.3. You have to edit the ProSystem.ini in the emulator folder and change Mode.BPP=8 to Mode.BPP=16
I've also used it with Mode.BPP=32 and it ran perfectly fine as well.
I know we have MESS now, but I still hope this helps anyone that is trying to overcome this issue!
