Mame List for Controls
admiralriker
Hello!
I got Don's Hyperspin Filter to limit the number of games displayed to those that I actually have (which is great).
Now I'd like to have a Mamelist.xls so that I know what controls it uses; I have an Extension Emulator Edition with a trackball and spinner. I want to create custom genres for Spinners and Trackball.
Everytime I try to do it, it gives me an error that it cannot create the mamelist.xls (Return Code 1).
Any advice?
you can make one with Romlister
https://www.waste.org/~winkles/ROMLister/
* Under Settings and tools
but you need 3 files
Mame listXML  -->  you can generate one from your MAME.exe
Controls.XML  --> list of games matched to the controls they use
Catver.lini. --> I believe this lists the genre/screen orientation  for each game.
Optional
nplayers.ini --> lists of number of players for each game
Unfortunately this files are no longer updated.  at least i cant find one for the latest MAME exe
(but I did not try very hard since I wanted it for a Retropie set up)
I have
Controls --> MAME 0 .140
nplayer -->MAME  0.172
Catver  --> not sure how old it is
nplayer --> MAME 0.172
I have attached my files,
my files will work,  they will not fill in the needed Controller info on the games added after 0.140
I suggest you use your google powers to see if you can find  newer versions.
romlister support files.zip
I forgot to mention this but
Romlister
will also also build a list of the games you want( spinner/trackball only)
and output the list as a HyperSpin compatible XML.
if I was building a Trackball/Spinner only game list
I would open MAMEUI64 (the version I"m using)
list Trackball Games only
copy and past  the parent rom found on the trackball  list to a new folder
generate a new XML based on the roms I copied to a new folder
the controls list is not 100% accurate  -->  720 the skating game is listed as a track ball game and we both know that's not true.
