Help With Mame Parameters
Griff08
Hey all. I need help knowing how to use the parameters block in the hyper HQ.
Under wheel settings, emulator, MAME, then the params block.
I would like to use -videoddraw -nohwstretch -switchres
Do I just enter it in like this: -videoddraw -nohwstretch -switchres
And then how will I know that it worked?
if you are using a version of mame with a GUI (mameUI etc) you can set these options in default game options and mame will remember them, most versions of mame (that ive used) will have a GUI version and dos version in the same package. I good way to do it is to set up mame in your GUI and then run mame from the dos exe (usually mamep.exe). Having said that mame GUI can be used with HS, no problems at all. You wont even know you're using it. Sorry about not answering your exact question. Been through my HyperHQ wheel settings and couldn't find any emulators that actually used the parameter box. :)
Thanks for the thoughts bud. I am trying to get these parameters working for my arcade monitor-> J-pac -> arcadeVGA setup. If I have to change emulators its not that big a deal. I was just hoping someone knew how to use the parameters box :)
judging from what im seeing in hyperHQ when i add parameters to mame, it looks like what you did in your first post was correct. HS seems to put the parameters after the rom name which i think is the way it should go. To test if it works, just add a parameter that is obvious. I cant remember the mame command line switches, but the best one to try would be disabling sound (maybe -nosound?).
Open your command prompt. Navigate to your mame directory.
Type MAME.exe -cc Or whatever your MAME.exe may be.
It will create a file called MAME.ini
Edit the MAME.INI and you can set all those options and many more.
Happy Gaming
You must defeat Sheng Long to stand a chance.
Thanks Brian. Works like a charm. Now my only problem is Mame does not want to run using direct draw. Is this because I am running windows 7?
Probably not? I think it may be a driver issue. Though I understand you may have your latest and greatest driver installed correctly.
Want to attach your MAME.ini that fails when set to ddraw?
  • 3 years later...
thanks, your post hinted me to something I was looking for and that was to skip the gameinfo at start (not the OK screen, but the screen after it)
For 64-bit official mame binary, open a command prompt (cmd):
cd c:\hyperspin\emulators\mame (go to mame directory)
mame64 -? (display options)
mame64 -createconfig (create the mame.ini file)
notepad mame.ini (open the mame.ini file)
change setting "skip_gameinfo" to 1 (to skip the gameinfo at start op)
close notepad and save the changes
