mamedude1967 Posted September 6, 2017 Posted September 6, 2017 I am having problems with the Nintendo DS emulator through Hyperspin. The emulator works fine but the wheels and videos do not work. They are in the correct folders. All my other systems work fine. Is this a bug? When I use Launchbox they work fine . Any assistance would be greatly appreciated.
gigapig Posted September 6, 2017 Posted September 6, 2017 Does all the naming of the media match the xml?
mamedude1967 Posted September 6, 2017 Author Posted September 6, 2017 Well renaming 1 vs 100 (USA) the correct way enabled the "Wheel icon". Enabling the video though is far more problematic. I'll continue to work on this next week. Any other suggestions are welcomed. Thank for the assistance thus far.
sparton Posted September 6, 2017 Posted September 6, 2017 no bug to speak of here, you need to ensure everything is named properly, in the right folders as per your XML for the system, check your settings.ini, specifically the start on favourites setting to see if you need a favourites.txt so it displays. If you can get in to the system and see the game listed but just no wheel, no video etc then things are not named properly or are not in the right location. Make sure your Hyperspin>Media>SYSTEM name folder is named the same as you called it in your database.
mamedude1967 Posted September 12, 2017 Author Posted September 12, 2017 I really don't understand all of the things that you are referring too. The XML is named right as is the system folder. I guess I'll use Don's tools to rename the wheels and Videos. Wish me luck.
