Pc games with a launcher
defre1976
Note that you can also run a specific configuration from command line (like in previous versions), running mpgr.exe using the -cfg switch. For example, if you wanted to run the pro_arcade_1360x768.cfg configuration from command line, you would specify   mgpr -cfg pro_arcade_1360x768.cfg
Taken from that forum page, if you use PC Launcher then add  the cli commands into the parameters field from the module to bypass the launcher.
To make an ahk script you need to figure out what keyboard combo you need to boot the game from the launcher. For all of my PC games I just need to press enter. I have an ahk script that on boot it waits a period of time then sends the enter command. Then you just need to tweek the wait time until you get it just right. Im away from my PC ATM but will post it tomorrow if you want it. I fairly sure its like 4 basic lines of code that I managed to google.
