Pinball Fx2 sound muted?
shitoken
Does any one know how to startup pinball fx 2 in window screen and not full screen?
Because each time I run the game outside RL , I don't get any sound and when I check the sound mixer it stay muted with red icon
There is no way for my mouse to point over and un mute it nor my keyboard shortcuts working.
I don't know why it is muted.
I also want my dot matrix to display on second screen , so I followed module instructions turned off the DMD but each time I run the game it goes back to main screen. How to fix this?
Does the sound get muted when you play the game without RL?
For the DMD I set mine in the game and set the coordinates as in the picture below. Yours will be different of course,  you can use mathematics or science to figure it out,  I used trial and error.
The picture is Pinball FX3 not 2, but its the same.
Thank you Gigapiggy
I will try this , about the sound I having issue both with and without RL.
While running the game in full screen if I press Ctrl, Alt, Del I can see the volume icon of pinballfx2 shows muted with red cross. But no way to turn it un mute , if I exit the game  pinball volume adjustment goes away. I cant find a way to do it unless the game  can run in window screen and let me use mouse to control the volume mixer to unmute.
