Pc games won’t launch? Pics
thenoob
Hey everyone
followed giga’s guide online but when I try to launch my only Pc game (duke Nukem) I get this weird prompt about a j:drive rom directory.
i don’t have a j drive and I cannot see anywhere that there’s anything pointing at any rom directory.  I have virtual emulator selected and I’ve got my single rompath pointed to the duke nukem steam application under pclauncher global module settings as shown.
anybody help?
It’s saying
cannot find “duke nukem” in any rom paths provided. J:/rooms and emulators/Roms/pcgames/ with any provided rom extension “zip|rar” etc
i really have never had any j drive and I’ve never set a rom path for pc games as you don’t need to, plus I’ve never had that rom directory
Usually need need either the Path to the program or the steam ID. Also not sue if you need it 3 times under different names..
I would also check your Rocketlauncher settings for PC Games and in Emulators.ini be sure there is no Rom_path= set.
Also in your Rocketlaucher settings maybe change the skip checks to Rom & Emu or try other combinations.
I would bypass using steam for now and just set the exe location. Also make sure the name in the [] in PClaunhcer.ini matches your item name in the database.
All you should need then in PCLauncher.ini is the following line.
[Duke3D]
Application=C:\Program Files (x86)\Steam\steamapps\common\Duke 3D Twentieth Anniversary World Tour\duke3d.exe
For now turn fade off in Rocketlauncher also appwait to disabled, once its working you can try and set them back up to enabled.
