Martycade Posted January 21, 2018 Posted January 21, 2018 I am new to hyperspin/rocketlauncher. i began to set up my system by following all the official hyperspin tutorials. everything was going good and seemed to be working well. then today i launched hyperspin, select nintendo, and select 1942. Absolutely nothing happened. this told me the likely problem was Hyperspin not comunicating with Rocketlauncer (or that is my guess). So i exhausted my self searching the forums and although i found lots nothing seemed to work and everyone elses problem was slightly different. I have Rocketlauncer and hypersin 1.4 . Attached is the hyperspin log. touble log 1.txt
Martycade Posted January 21, 2018 Author Posted January 21, 2018 07:51:28 PM | HyperSpin Started 07:51:28 PM | Going windowed mode 07:51:28 PM | Checking for updates 07:51:28 PM | Update Check Complete 07:51:28 PM | Startup program unavailable 07:51:28 PM | Playing intro video 07:51:31 PM | Error intializing joysticks 07:51:31 PM | Menu Mode is multi 07:51:31 PM | Loading Main Menu.xml 07:51:31 PM | Main Menu.xml successfully loaded 07:51:32 PM | Main Menu wheel loaded successfully 07:51:34 PM | Loading Nintendo Entertainment System.xml 07:51:34 PM | Main Menu.xml successfully loaded 07:51:34 PM | Nintendo Entertainment System wheel loaded successfully 07:51:38 PM | Launching Game 07:51:38 PM | Using HyperLaunch 07:51:38 PM | Getting Launcher path 07:51:38 PM | Launcher located at C:\MartyCade\RocketLauncher\RocketLauncher.exe 07:51:38 PM | Running Launcher 07:51:38 PM | Launcher Command Line is: C:\MartyCade\RocketLauncher\RocketLauncher.exe "Nintendo Entertainment System" "1942 (Japan, USA)" 07:51:53 PM | Loading Main Menu.xml 07:51:53 PM | Main Menu.xml successfully loaded 07:51:53 PM | Main Menu wheel loaded successfully 07:51:55 PM | Exit program unavailable 07:51:55 PM | Quiting Hyperspin 07:51:55 PM | Bye!
Bungles Posted January 21, 2018 Posted January 21, 2018 Do the games work if you load them from within RocketlauncherUI? Do do this you select your Nintendo Entertainment System from the left menu in RocketlauncherUI. Then press the Games Button up the top in the menu. Then list the games either by pressing the Audit Button or the List Games button. (Audit Games will check/verify that the games are found and will highlight green, so recommend using that one.) Then press the little rocket-ship to load your game. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
Martycade Posted January 21, 2018 Author Posted January 21, 2018 no they did not. I did some digging within my system and found out RocketLauncher was running in the hidden icon menu which was the first time i have ever noticed it. I right clicked on it and select exit. i then restarted my computer and everything in NES SNES (all console) systems are working perfectly. i found that strange. However, the exact same problem is still occuring when i try to launch a MAME game. 10:02:02 PM | HyperSpin Started 10:02:02 PM | Going windowed mode 10:02:02 PM | Checking for updates 10:02:02 PM | Update Check Complete 10:02:02 PM | Startup program unavailable 10:02:02 PM | Playing intro video 10:02:05 PM | Error intializing joysticks 10:02:05 PM | Menu Mode is multi 10:02:05 PM | Loading Main Menu.xml 10:02:05 PM | Main Menu.xml successfully loaded 10:02:06 PM | Main Menu wheel loaded successfully 10:02:08 PM | Loading MAME.xml 10:02:08 PM | Main Menu.xml successfully loaded 10:02:08 PM | MAME wheel loaded successfully 10:02:14 PM | Launching Game 10:02:14 PM | Using HyperLaunch 10:02:14 PM | Getting Launcher path 10:02:14 PM | Launcher located at C:\MartyCade\RocketLauncher\RocketLauncher.exe 10:02:14 PM | Running Launcher 10:02:15 PM | Launcher Command Line is: C:\MartyCade\RocketLauncher\RocketLauncher.exe "MAME" "goldnaxe" 10:02:21 PM | Launching Game 10:02:21 PM | Using HyperLaunch 10:02:21 PM | Getting Launcher path 10:02:21 PM | Launcher located at C:\MartyCade\RocketLauncher\RocketLauncher.exe 10:02:21 PM | Running Launcher 10:02:21 PM | Launcher Command Line is: C:\MartyCade\RocketLauncher\RocketLauncher.exe "MAME" "gng" 10:02:23 PM | Loading Main Menu.xml 10:02:23 PM | Main Menu.xml successfully loaded 10:02:24 PM | Main Menu wheel loaded successfully 10:02:24 PM | Exit program unavailable 10:02:24 PM | Quiting Hyperspin 10:02:24 PM | Bye! not sure why the console emulators and games are all working but not the mame. any thoughts and suggestions
Bungles Posted January 21, 2018 Posted January 21, 2018 Just need to check your preferred mame is setup correctly. See which one you have chosen by selecting Mame and then the emulators tab. Then if you choose Global on the left and the the Emulators button, scroll down your list and check the path to the exe is set correctly. Also be sure you can launch the emulator directly and also perhaps check for compression options if your roms are ziped etc. Sometimes you may have to check your skip checks settings. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
Martycade Posted January 21, 2018 Author Posted January 21, 2018 Within Rocketlauncher: Default Emulator: MAME (Global) Went to Global Tab and emulators and double clicked on Mame and the path and everything was correct. Still on the global tab and emulator tab i launched Mame. This is where it gets weird. First off a WINDOWS popup shows up and says "Search for app in Store? You need to install app for this task" so i click yes. It doesnt look for an app or anything but Mame opens. So i close mame and relaunch it again. and the exact same WINDOWS message pops up. this time i select NO and it still opens mame. not sure what is going on there but i would love to stop that window from popping up. Now if i Click on MAME on the left hand side. then i click on Games tab on the top. I then click on "Audit all games for this system" My games show correctly. so i select a game and click on the rocket to launch game and nothing happens. So i am thinking that something is wrong with my roms settings or something. The rom set is in rom folder and are all in Winrar zip files. Could you explain what you stated here more in depth "Also be sure you can launch the emulator directly and also perhaps check for compression options if your roms are ziped etc. Sometimes you may have to check your skip checks settings. " EDIT: I went through rocket launcher log file and noticed it said mame was already running error. so I hit CONTROL+ALT+DELETE to open taskmanager after closing everything that was open. task manager showed nothing operating however i found in the background proccesses that "Mame64" was running so i closed it. I then opened rocket launcher and tried launching a game and the stupid "search for App" window poped up again and i hit yes and it opened the game. I then exited the game and tried launching another game and it worked. so i am guessing mame exe just never exited properly one time and it was giving me problems. so now my only issue is that stupid "Search for App in Store" window Any thoughts? thanks
