TwistyPixels Posted January 22, 2018 Posted January 22, 2018 Hi there, first post here and HS noob! I'm trying to create a main menu theme with cinematic backgrounds UNDER the wheel, i.e. have the wheel always showing on top of everything else. I can get the videos playing full screen etc just fine using the default theme XML, but because of the way the themes are layered with the wheel, the video layer always hides it. Even with Alpha set set to 1 in HyperHQ. Are there any settings to change to have the wheel stay on top? OR failing that, a way to have the video as the background layer so it would be underneath?
wesfranks Posted January 22, 2018 Posted January 22, 2018 Depending on what specifically you are looking for, this might give you some options. First, back up your original <your theme>.xml. Work off of a copy. Top two based on 1080p video so if yours is not, the coordinates will be off. Don't change all settings, just experiment with one or two at a time. May start with "below="false" or below="true". These are a comparison of most of the instructions for the cinematic themes by different artists. I might go into more depth, but I have a fever and (sorry) I don't feel like sitting in this chair right now. Again, sorry!
TwistyPixels Posted January 22, 2018 Author Posted January 22, 2018 1 hour ago, wesfranks said: May start with "below="false" or below="true". That was it! Thank you very much! Can't believe it was so simple, cheers.
