Need HELP..
LarryLaffer75
Hello guys,
i am a fresh member of this hyperspin forum and i need your help. Sorry about my english, it is very bad.
ok, i will try to explain my problem.
I have two arcade cabinets. The first one i bought last year, it is a table cabinet and it works good. Last days
i get one new big cabinet with power and control unit, the control unit has an jamma plugin. The table cabinet
has an ipac to usb.
So, i bought the hardware for the big cabinet..
 - Intel Core i5-7500 7. Generation (Quadcore) Kabylake 4x 3.4 GHz
 - 8 GB DDR4 2133Mhz
 - ASUS PRIME Z270-P
 - 2048 MB Nvidia Geforce GTX 1050
Today i put the harddisk from the little cabinet into the big one. The system starts without a problem, but...
the controller doesn´t work? I think i have to configure the jamma plugin. Problem is, that i cannot start
windows! ALT+F4 doesn´t work?
I need a little help to get the controller working!?
Thx a lot..!
How are you connecting the JAMMA harness to the PC? If you don't have it connected right now, you'll need something like a J-PAC.
If you press CTRL + SHIFT + ESC to bring up the task manager, you then should be able to select File then Run New Task and type in Explorer
That should load windows in the background unless its been disabled via group policy.
If its been locked down completely you might have to boot into Safe Mode and set the login screen to display.
Commonly when someone locks down the Custom User Interface there will be a secondary account you can login with which will load explorer.exe instead of hyperspin.exe as the default.
If that fails search the web or contact the person that sold you the cabinet and ask them for a "cheat sheet" or some instructions/help so you can customize/configure.
Ok, it works. I can enter Windows 10. Problem was the confitguration in Bios.
The next problem is, that the controller does not work. Do i have to install something for the jamma harness?
