lucasbr21 Posted February 19, 2018 Posted February 19, 2018 Help when I go to lauch the sega model 2 game list on hyperspin is just reset and I back at the menu screen to chose my sytem help me
edgecom Posted February 19, 2018 Posted February 19, 2018 you need to enter a valid rom directory from hyperHQ for the system you want to play also make sure you enter the extensions in the extension box if your roms are winzipped then you need to pit zip in the extensions box
lucasbr21 Posted February 19, 2018 Author Posted February 19, 2018 it work now I just select the same rom directory as befor form hyperHQ and it work edit: it dose not want to open the roms when i click daytona usa for exemple it dose noting
Spawk Posted February 20, 2018 Posted February 20, 2018 it work now I just select the same rom directory as befor form hyperHQ and it work edit: it dose not want to open the roms when i click daytona usa for exemple it dose noting 1. Make sure you can run it from outside RL/HS first... just in the model 2 emu.2. Then make sure audit in RL shows game as green. And then run from there.3. Last step is running from HS itself.This is the basic workflow when adding any system. Knowing which number you are on will help others know what setting needs changed.* just as a side note for model 2. Each game will have to be loaded and controls set inside each game with the "tab" key.Sent from my SM-A520W using Tapatalk
