MAME 0.194 DEFAULT BEZELS
Creezz67
Hi,
Has anyone got/seen any other default bezels that work with MAME 0.194 ?
horizont.zip & vertical.zip now work to replace games without bezels, but there only seems to be one set that currently works with MAME that for me don't look too good.
Thanks in advance for any info provided.
Hi,
Assuming you're using mine (screenshot?): not that I know of, but let me know if you find some so I can add them to the bezel set.
Sent from my SM-G950F using Tapatalk
Hi,
Yes I really appreciate the option to use default bezels, but the horizontal one is just not ideal for me.
I got this vertical one to work if you want to add it to your set ?
It just the default.lay settings that don't match my MAME horizontal one I have.
Thanks again
Hi,
Thanks again
Can you upload your horizontal bezel zip file? I'll have a look.
Hi,
See zip attached of default MAME bezel I have.
This is the horizontal bezel i have, bezel just does not show up when in use.
As I say the default.lay is different compared to bezel, but no idea how to change.
Thanks
horizont.zip
Hi,
Thanks
horizont.zip
It doesn't show up at all, doesn't show up in the video options, shows stripes, or is the screen smaller than expected?
The file itself seems fine, but the screen settings are incorrect (too small), and should be 240, 0, 1440, and 1080 (x, y, width, height).
Your bezel works perfectly and when bezel does not exist it just gets replaced automatically with your bezel
Any other bezel used just does not show up for some reason, even when renamed to what your one is called inside zip
I think i found one that works automatically (just replaces missing bezel automatically)
This works using your horizont.zip
Thanks again for all your work. Just personal preference for me.
horizont.zip
