Can anyone post a link to download the hyperlaunch 2.0 dolphin module?
sparky1821
From what I've read, I guess HL 2.0 modules are a thing of the past. I did download hl 3.0 two days ago, the only problem is...I already had 30 systems perfectly edited, setup and working and it just seems like too much to go back through and set everything up again when all I want to do is add gamecube with my current hl 2.0 setup. I've spent about 15 hours with hl 3.0 and it looks absolutely awesome, it's just that I already had so much set up...and now my emulators wont stay in full screen...they won't remember new key configs etc...and I've only been trying to convert 3 easy emulators, I am seriously considering just going back to HL 2.0 from my backup drive, and just trying to obtain the dolphin.ahk for dolphin 4.0 (HL2.0module) from somebody in the forums .....thoughts???
any help would be appreciated,
Thanks!! :)
Sparky
for starters if you go in hlhq you can edit global module settings by clicking on edit specific module settiings or edit global module settngs as long as your on the modules tab i would advise you to use the modules that are supplied for hlhq as there designed and made specific to work with it you can set full screen when you go in module settings -
2nd you use keymapper option and press + to add in a xpadder profile for your system then press edit to add the keys of your choice and finally save
the 2.0 modules do not work with hlhq or if they do with great diffcuilty it takes to get them running/
if emulators dont show up in the listing you have to go in hyperlaunch folder and scroll down to you see global emulators example.ini if you see that rename it to global emulators
and finally go up to global emulators tab and click on emulators tab to bring up the list of supplied modules choose the one of your choice and double click it
to turn on xpadder go to general settings tab or settings and turn on xpadder then choose the location of it and finally change keymapper to xpadder and thats it your done if it works enable hyperlaunch profile and turn on joy ids.
sig.png 100%
hello, thank you for the response, I'll have to look into your input on the fullscreen tip, I have figured out the whole xpadder thing, and have it working all the way to the point where I launch games, but when I upgraded to HL 3.0 it wiped all my emu settings to the default from when I downloaded them, and when I try to change them to new configs, they keep reverting back to fresh download status when I launch through HL 3.0, maybe I just need to spend more time with it, but it seems a little overwhelming, and I've spent 1600 hours with hyperspin, (although it's been a while) if I did revert back...I wouldn't be using HLHQ at all, my build I'm trying to add to is from late 2011 I think, thanks for the imput
Ok so let me clarify, right now, zsnes, the same one I used before, is full screen...but it reset the resolution, so the viewimg window is really small even though its fullscreen, and all the emulator key imputs were reset, if I change resolution then exit emu then launch straight from emu the changes stay...but if I launch from hl it reverts back to tiny resolution screen size. If I remap keys they will stay that way in emu and I launch a matching xpadder profile, but when launching game its still setup for default controls. Example: changed start to m in emu and xpadder profile, start game and it still wants me to press enter
Genesis also reset all my custom emu keymapping settings and took away widescreen, thats as far as I got last night.
Any help is appreciated thanks
