LarryLaffer75 Posted March 23, 2018 Posted March 23, 2018 Hey, I installed RetroArch, hope correctly, for NES. When i start RockeLauncherUI i get this.. If i try to start a game, then i get this Error.. "YOUR LIBRETRO_NES DLL IS NOT SET TO NESTOPIA_LIBRETRO BUT COULD NOT LOCATE THIS FILE E:\HYPERSPIN\EMULATORS\TETROARCH\CORES\NESTOPIA_LIBRETRO.DLL2
thatman84 Posted March 23, 2018 Posted March 23, 2018 Have you run retroarch directly and confirmed a game works? Load Content>select game>Nintendo (Nestopia) should be listed as a core to play the game with If its not listed go the Online Updater >Core updater and download the Nestopia core. Although I believe the fceumm core is the preferred core these days Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Peliculon Posted March 23, 2018 Posted March 23, 2018 Hmmm... I assume that you have install RetroArch emulator in the RLUI. Open RLUI, go to GLOBAL, chose Emulators. Then select the RetroArch emulator (be sure that you have the extension for run nes games, if not, copy/paste this to the RetroArch extensions: 7z|2hd|3ds|3dsx|3g2|3gp|32x|68k|88d|a26|a52|a78|abs|agb|app|asf|atr|atx|avi|axf|ay|bml|bmp|bin|bs|bsx|caq|cas|cbn|ccd|cci|cdg|cdi|cdm|cdt|cgb|ch8|chai|chailove|chd|cmd|cof|col|cpr|cso|cue|cxi|d88|dim|divx|dmg|DOOM|dsk|dup|dx2|elf|exe|f4f|f4v|fds|fig|flac|flv|game|gen|gb|gba|gbc|gbs|gd3|gd7|gdi|gg|gif|gym|hes|hdf|hdm|hdr|img|int|ipf|iso|j64|jag|jpg|jpeg|kcr|kss|lnx|lua|lutro|m2p|m2ts|m3u|m4a|md|mdf|mdx|mgw|min|mkv|mov|mp3|mp4|mpg|mpeg|msa|mtl|mx1|mx2|mxf|n64|ndd|nds|nes|ngc|ngp|nsf|nsfe|obj|ogg|ogm|p|pak|pbp|pic|pce|pgm|png|ppm|prg|prx|ps|psd|psx|rar|ri|rom|rzx|sap|sc|scl|scummvm|sfc|sg|sgb|sgx|smc|smd|sms|sna|spc|st|st2|stx|sv|swc|t81|tap|tga|toc|trd|ts|tzx|u1|unf|unif|uze|v64|vb|vboy|vec|vgm|vgz|vob|voc|wav|webm|wma|wmv|ws|wsc|xdf|xex|xfd|z64|z80|zip lol Well, select your RetroArch emulator and then, in the little icons open "Edit Global Module Settings". Then select your NES system with double clic. A new window will open. There you will see 4 sections: Settings, Network, Nintendo Entertainment System and Rom Settings. Choose NES, and then the first option say: "LibRetro_Core". There you need to put where is you nestopia_libretro core. I hope this solve your problem
LarryLaffer75 Posted March 23, 2018 Author Posted March 23, 2018 Retroarch is running, there i can Play a game. now i have installed Nestopia and everything is good. Do i Need retroarch?
LarryLaffer75 Posted March 23, 2018 Author Posted March 23, 2018 peliculon. Thx, now it works with retroarch. OMG, a lot of ways to configure the Emulators. And a very very big THX to you all guys. This is a very good Forum..!
