PCSX2 plugins not a valid dynamic library
badboo
Hi everyone,
I just migrated my hyperspin setup to a new PC setup, I got an older cpu: i7 930 @2.80 ghz
I am getting some issues now to run PCSX2 on rocketlauncher now. I get an error with padpokopom.dll plugin that it is not a dynamic library.
I don't know how to fix it. I run pcsx2 outside RL and runs well, but on RL I get that error.
PCSX2 1.5.0-20180112142120 - compiled on Jan 12 2018
Savestate version: 0x9a0d0000
Host Machine Init:
	Operating System =  Microsoft Windows 10 Pro (build 16299), 64-bit
	Physical RAM     =  8183 MB
	CPU name         =  Intel(R) Core(TM) i7 CPU         930  @ 2.80GHz
	Vendor/Model     =  GenuineIntel (stepping 05)
	CPU speed        =  2.805 ghz (8 logical threads)
	x86PType         =  Standard OEM
	x86Flags         =  bfebfbff 0098e3bd
	x86EFlags        =  28100000
x86 Features Detected:
	SSE2.. SSE3.. SSSE3.. SSE4.1.. SSE4.2
Reserving memory for recompilers...
Loading plugins from H:\Hyperspin\Emulators\pcsx2-v1.5.0-dev-2253\plugins...
	Bound   GS: gsdx32-sse2.dll [GSdx 20170613011145 (MSVC 19.00 SSE2/SSE41) 1.1.0]
	Bound  PAD: lilypad.dll [LilyPad (20170613011145) 0.12.1]
	Bound SPU2: Spu2-X.dll [SPU2-X 20170613011145 2.0.0]
	Bound CDVD: cdvdgigaherz.dll [cdvdGigaherz 20170613011145 0.11.0]
	Bound  USB: USBnull.dll [USBnull Driver 20170613011145 0.7.0]
	Bound   FW: fwnull.dll [FWnull Driver 20170613011145 0.7.0]
	Bound DEV9: dev9null.dll [DEV9null Driver 20170613011145 0.5.0]
Plugins loaded successfully.
(GameDB) 9714 games on record (loaded in 221ms)
[wx] Failed to load shared library 'H:\Hyperspin\Emulators\pcsx2-v1.5.0-dev-2253\plugins\DEV9ghzdrk.dll' (error 126: the specified module could not be found.)
[wx] Failed to load shared library 'H:\Hyperspin\Emulators\pcsx2-v1.5.0-dev-2253\plugins\gsdx32-avx.dll' (error 1114: a dynamic link library (DLL) initialization routine failed.)
[wx] Failed to load shared library 'H:\Hyperspin\Emulators\pcsx2-v1.5.0-dev-2253\plugins\padPokopom.dll' (error 126: the specified module could not be found.)
Thanks @oldhag270, you led me to the right direction.
After thinking a minute about the locations, I checked this post:
PCSX2 GSdx.ini Error   and I noticed that this guy had a different pluging for the PAD. So I changed to Lily (I had padpokom before) and it is working now.
