jevansoh Posted April 4, 2018 Posted April 4, 2018 I have a problem I hope someone can help me with. When I press enter to launch a game, nothing happens for about 10 seconds. It doesn't matter which system I'm on or which emulator it's using. After about 10 seconds, finally, the fade in screen will come up and it will start launching the game. I want it to do "something" immediately after I press enter, though, because other people using my cabinet think it's broken and I see them press the enter key over and over and over again, thinking something is hung up or not working, when all they have to do is wait 10 seconds. I just think 10 seconds is way too long to have to wait before something starts happening. Is this normal behavior? Is there anything I can do about it? If I launch a game from RocketLauncher, it's almost instant, so it's definitely something with HyperSpin or some setting(s) somewhere. Thanks, --Jason
Creezz67 Posted April 4, 2018 Posted April 4, 2018 Try going into RL, Settings, fade-general and see if the fade in duration or delay settings are set too high (or see global setting to change for all systems) if so just change to what you require.
jevansoh Posted April 4, 2018 Author Posted April 4, 2018 Ok, it was set to 5000. I set it to 0. Then I turned fade in off altogether. That made no difference. Thanks for the tip, though. Any other suggestions?
jevansoh Posted April 4, 2018 Author Posted April 4, 2018 I just did some more testing and need to amend my original post. If I try to launch a game directly from RL, it still takes 10 seconds before the fade screen shows up. So it's not a HyperSpin problem, per se. I've made a post over on the RL forum, but if anyone here has any ideas, I would really appreciate it. Thanks, --J
