SSF Fullscreen Error
peabody9
So I am having luck in rocketlauncher running SSF in windowed mode, but when i try to switch to fulslcreen via alt+enter, i get a directx error.   If i set RLUI to go to fullscreen automatically i get the same error.
tried getting mednafen setup but it refuses to launch, and retroarch is out because i cant get it open in crtemudriver
any help would be appreciated.  Thanks!
  • 4 months later...
You can try removing or deleting the SSF.ini from your SSF install if something is bad in there. A new one will be created when you run it again.
Yeah that work too been away but back to help but I'm not helping just certain fes I'm learning them all so I can provide help for what is needed help with
Sent from my H710VL using Tapatalk
