krikon Posted April 14, 2018 Posted April 14, 2018 I'm still trying to configure all the emulators, this time I'm having problems with SSF, the Saturn emulator. the game loads and then nothing happens, when I push enter a few times I get the error "drive door open" and a black screen, and the SSf window can be "kinda" seen. Anyone knows how to fix it? Iv'e been at it for a while now. (I will try and not come across as an asshole this time lol :D) Let me ad that I use windows 10 and daemon tools 10.5xx, I watched the tutorial from SimplyAustin but he goes on and on babbling and left out a bunch of important info I found elsewhere.
krikon Posted April 16, 2018 Author Posted April 16, 2018 So, am i the only one having run into this problem? Is there no one who can help me on this?
Spawk Posted April 16, 2018 Posted April 16, 2018 On 4/16/2018 at 6:31 PM, krikon said: So, am i the only one having run into this problem? Is there no one who can help me on this?I can check mine in about 5 hrs when i get home from work. Cant promise anything as i use win7 and and an older version of daemon though.Sent from my SM-A520W using Tapatalk
krikon Posted April 17, 2018 Author Posted April 17, 2018 thanks, I got a bunch of the other emulators up and running so if Saturn is the only one I cant get going I guess I can live with it, it be cool to have it working though, I'm greedy with roms lol
Spawk Posted April 17, 2018 Posted April 17, 2018 On 4/17/2018 at 8:49 PM, krikon said: thanks, I got a bunch of the other emulators up and running so if Saturn is the only one I cant get going I guess I can live with it, it be cool to have it working though, I'm greedy with roms lol Yeah i think ssf is the last system to still use dtools. Not sure what u have/have not done so heres a couple of ideas.Since you are running win10 can I assume you are running both HS and RL as administrator?In RLUI under global/general settings/third party, the path should be to dtlite.exe not dtagent.exeUnder sega saturn/settings/main settings, both virtual drive enabled and use scsi both set to true.If your games are zipped then also enable 7z here.If you edited the names of your bin/cue files then you also have to open the cue in notepad and change the filename there as well.Sent from my SM-A520W using Tapatalk
thcdgaf Posted September 3, 2018 Posted September 3, 2018 On 4/17/2018 at 10:06 PM, Spawk said: Yeah i think ssf is the last system to still use dtools. Not sure what u have/have not done so heres a couple of ideas.Since you are running win10 can I assume you are running both HS and RL as administrator?In RLUI under global/general settings/third party, the path should be to dtlite.exe not dtagent.exeUnder sega saturn/settings/main settings, both virtual drive enabled and use scsi both set to true.If your games are zipped then also enable 7z here.If you edited the names of your bin/cue files then you also have to open the cue in notepad and change the filename there as well.Sent from my SM-A520W using TapatalkMake sure your virtual drive is mounted right it's reason the ssf says door is open Sent from my H710VL using Tapatalk
