New Arcade build complete. Now I'm having controller problems.
Nufactor27
Hey everyone.
I just finished building my arcade and it looks sweet. For the life of me I can't get and controllers working. Someone please help
I have 2-Player Ipac
sanwa joysticks
seimitsu button
windows 10 pc
hyperspin setup with rocket launcher
mame roms and emulator
snes roms and emulator
hypersync all synched up with emumovies and hypersonic account. mame and sees art and everything loaded.
when I start HyperSync everything looks great...
I can move up and down to go through emulators and games but I can't start a game. None of the buttons work for player 1 start or player 2 start.
I just want to go through my list select a game and play. can someone please walk me through on how to set up buttons to control Hypersnyc.
I went into HyperHQ and made sure joystick and the other two were not enabled. I went through the control settings and those button work as programmed. but what starts the actual game? there is no start command or enter.
I am a super newb at this so I need simple explanations please.
Hey everyone.
sanwa joysticks
seimitsu button
windows 10 pc
Player 1 and Player 2 start are used once inside an emulator (like mame), but by default the enter key is used to start a game from the HS wheel. Does enter on the keyboard start a game?
Enter does not start anything . I pressed every button on the keyboard and nothing started the game. isn't there a way to set my arcade controller to navigate through hyper spin without the use of a keyboard?
SOunds like maybe the problem is that Rocketlauncher is not taking over, not that the start button is wrong - the other controls work right - but that the game can't actually start?
Make sure Hyperlaunch is enabled for your system(s) properly in Rocketlauncherui, in Hyperhq, in your settings.ini files.
Sparton
I followed so many different  tutorials and am beyond frustrated. As far as your recommendation, I really don't know where or how to start. where are my ini files?
Hyperspin folder > Settings >
there's an ini file for each system
inside the ini file there's a line which should be
hyperlaunch=true
Rocketlauncher > RocketlauncherUI > RocketLauncherUI.exe
Global > General Settings > Rocket Launche tab
Default Plugin  = RocketLauncherUI
ok in the hyper spin folder each system ini show Hyperlaunch=true except global settings and main menu.
for rocket launcher. I just changed the base settings default plug in to RocketLauncher. it was hyper spin.
should it work now?
should it work now?
HS was correct plugin to select in RLUI.
OK, so we need to find out why ENTER is not working. I will just start with the basics to make sure ok. First thing is HQ:
Also make sure every system (mame pictured here) has "hyperlaunch" selected for execution:
(* rompath and extensions here are only used to populate the wheel when using a filter)
And that HS knows that RocketLauncher is the new hyperlaunch:
(* I use Z: drive but should be your path obviously)
