evilmrfrosty Posted May 6, 2018 Posted May 6, 2018 Hello Been trying for hours now to set up the Nintendo Gamecube system in Hyperspin/Rocketlauncher. All games run fine through Dolphin directly, but when I try and test them via RocketLauncher UI, I get the following error "There was an error waiting for the window 'FPS ahk_class wxWindowNR'. Please check you have the correct version emulator installed for this module..." Can anyone give me any guidance on this before I tear out what little hair I have left?! It’s Dolphin v5.0-7259 I’m trying to use Thanks! Log file is attached RocketLauncher.log
Creezz67 Posted May 7, 2018 Posted May 7, 2018 Hi, In RocketLauncher point Dolphin emulator to DolphinWX.exe as newer version's of Dolphin nightly are not currently working with latest module. Works fine doing it this way for newer versions as DolphinWX is basically the version of Dolphin that worked previously. Both should be in folder when you download it. I have reported it to RL and they are looking into it.
evilmrfrosty Posted May 7, 2018 Author Posted May 7, 2018 Thanks - tried this and unfortunately didn't seem to work for me Found an older version of Dolphin Ishiiruka though, which seems to do the trick!
mdog1978 Posted May 7, 2018 Posted May 7, 2018 I think there was an edit to the Dolphin module in RL a few months ago too that probably isnt in the version you have. Check the RL forums and you should find a thread about it and what needs to be changed.
Creezz67 Posted May 8, 2018 Posted May 8, 2018 I am using it perfectly fine pointing to DolphinWX.exe on my system and have updated to latest version 2-3 times now with no issues (Windows 7 64bit) Recommended by RocketLauncher till module is updated. They know it's an issue as of a few weeks ago on Dolphin nightly.
evilmrfrosty Posted May 8, 2018 Author Posted May 8, 2018 14 hours ago, mdog1978 said: I think there was an edit to the Dolphin module in RL a few months ago too that probably isnt in the version you have. Check the RL forums and you should find a thread about it and what needs to be changed. Thanks for this - will give it a try tonight 2 hours ago, cataclysm67 said: I am using it perfectly fine pointing to DolphinWX.exe on my system and have updated to latest version 2-3 times now with no issues (Windows 7 64bit) Recommended by RocketLauncher till module is updated. They know it's an issue as of a few weeks ago on Dolphin nightly. Perhaps should just try and download the last stable release rather than one of the latest development ones?
Creezz67 Posted May 8, 2018 Posted May 8, 2018 All versions of the Dolphin nightly emulator up to version 5.0-7062 work fine using Dolphin.exe, but nightly versions after this need to be set to run using DolphinWX.exe until module is updated.
