TheChopman Posted June 2, 2018 Posted June 2, 2018 Guys, It's been asked a bazillion times I'm sure...but... I am able to launch roms from Rocketlauncher but cannot from Hyperspin. When I press enter to keyboard to launch the game nothing happens. Can someone help me please. Below in an extract of my log file: 11:55:11 PM | Using HyperLaunch 11:55:11 PM | Getting Launcher path 11:55:11 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 11:55:11 PM | Launcher located at E:\Hyperspin\Hyperspin\HyperLaunch.exe 11:55:11 PM | Running Launcher 11:55:11 PM | Launcher Command Line is: E:\Hyperspin\Hyperspin\HyperLaunch.exe "Sega Genesis" "Alex Kidd in the Enchanted Castle (USA)" 11:55:12 PM | Launching Game 11:55:12 PM | Using HyperLaunch 11:55:12 PM | Getting Launcher path 11:55:12 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe 11:55:12 PM | Launcher located at E:\Hyperspin\Hyperspin\HyperLaunch.exe 11:55:12 PM | Running Launcher 11:55:12 PM | Launcher Command Line is: E:\Hyperspin\Hyperspin\HyperLaunch.exe "Sega Genesis" "Alex Kidd in the Enchanted Castle (USA)" 11:55:13 PM | Loading Main Menu.xml 11:55:13 PM | Main Menu.xml successfully loaded 11:55:14 PM | Main Menu wheel loaded successfully 11:55:15 PM | Exit program unavailable 11:55:15 PM | Quiting Hyperspin 11:55:15 PM | Bye! TIA TheChopman
Spawk Posted June 2, 2018 Posted June 2, 2018 You are still using hyperlaunch, update the path to RL in Hyperspin/Settings/Settings.ini
TheChopman Posted June 2, 2018 Author Posted June 2, 2018 Hi Spawk, The settings already have the correct path to RL: [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=Sega Genesis Hyperlaunch_Path=E:\Hyperspin\RocketLauncher.exe Just cannot work it out, I'm sure its something simple.
Spawk Posted June 2, 2018 Posted June 2, 2018 I am away from home atm but there should be a "default frontend" or something option in RLUI. Make sure HS is selected.Tip: its not the one with default and active profile. There is another one under general settings.Sent from my SM-A520W using Tapatalk
Spawk Posted June 3, 2018 Posted June 3, 2018 Hi Spawk, The settings already have the correct path to RL: [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=Sega Genesis Hyperlaunch_Path=E:\Hyperspin\RocketLauncher.exe Just cannot work it out, I'm sure its something simple. Ah... well its clearly not finding RL and still using hyperlaunch.You have your RL folder inside HS folder??? I know hyperlaunch is usually there but RL is ideally setup in its own folder now.Sent from my SM-A520W using Tapatalk
Bungles Posted June 3, 2018 Posted June 3, 2018 Just beat me to it Spawk. That path does't seem correct, if it is you will probably have more problems to deal with. As Spawk advised be sure RL is in its own folder so you don't have settings conflicts. Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
Mark Norville Posted June 11, 2018 Posted June 11, 2018 On 03/06/2018 at 3:55 AM, Spawk said: Hyperlaunch_Path=E:\Hyperspin\RocketLauncher.exe I bet you are copying simply waffle on how to set this up As said you should have it outside of hyperspin, if you are copying his waffle, also hyperspin should be in it's own directory so e:\Hyperspin\RocketLaucher\RocketLaucher.exe If you have moved the exe file, rather than using a short cut rocket launcher will not know where the file is, even a short cut can be dodgy, as that is a different file extension. Also you have the following 11:55:11 PM | Launcher Command Line is: E:\Hyperspin\Hyperspin\HyperLaunch.exe "Sega Genesis" "Alex Kidd in the Enchanted Castle (USA)" You shouldn't have hyperspin\hyperspin your directories are all wrong. Hope this helps. Regards Mark Proud to be part of the Hyperspin community.
