newer Posted May 9, 2014 Posted May 9, 2014 Hallo everybody... i will ask you all how can i make a Hotkey in the Script from the Nestopia Emulator. I need a Hotkey for the Nintendo Disc System to start with the Hotkey the Disc B... What i have to do to generating a Hotkey.. Please help.... Also in the System: American Laser Disk i need a Hotkey (Letter F) that the Emulator starting in Fullscreen
Deadly Posted May 9, 2014 Posted May 9, 2014 Also in the System: American Laser Disk i need a Hotkey (Letter F) that the Emulator starting in Fullscreen Maybe things have changedsince the new Hyperlaunch program, but long ago I also looked for a way to send (F) for full screen long ago and gave up and just used SINGE. This allows you to send a multitude of commands to suite your needs. More or less you have to convert your games to Singe. If you don't have the original CD I found that you simply use a program like IMGBURN to create an ISO of the games files/folders. Then you mount that ISO with Daemon Tools. At that point you have a "CD" for all intent and purposes and you run the appropriate installer for the game. After 20-30 minutes it will create a SINGE ready version of your game with a bat file to launch with. You'll want to edit that file and make it look like this: @daphne.exe singe vldp -fullscreen -framefile singe/crimepatrol/frame-crimepatrol-cdrom.txt -script singe/crimepatrol/cdrom-crimepatrol.singe -noserversend Alter the name where appropriate - just an example of what each bat file should look like. Download the conversion installers from HERE Download the SINGE DAPHNE version from HERE
