stonemask Posted June 25, 2018 Posted June 25, 2018 Hi there, I decided to dive back into the Hyperspin thingy and am trying to set things up again. I do have one question though, which is probably trivial...but...how do you know which version of mame64.exe to use? Mame version as of today is: 0.198 The Hyperspin database is at: 0.160 So, is it safe to assume that the romset and mame64.exe to be used shoud be 0.160?
phulshof Posted June 25, 2018 Posted June 25, 2018 No, you should use the 0.198 XML from the RetroFE website, and the 0.198 romset.Sent from my SM-G950F using Tapatalk
Rowr14 Posted June 25, 2018 Posted June 25, 2018 You always want to use the same version of Mame as the Romset you are using. So you are following the correct logic for things to all work correctly, but you might as well get the latest versions of everything.
stonemask Posted July 2, 2018 Author Posted July 2, 2018 thx for your replies, I got the 0.198 from retrofe and am now deciding which xml to use, there are so many different versions but very much welcomed, since there´s no need to list all the games
Maelo1212 Posted July 6, 2018 Posted July 6, 2018 Tal vez no sea el lugar correcto pero alguien sabe como configurar el HyperSync?
