SIMPLYAUSTIN Posted May 10, 2014 Posted May 10, 2014 Like it says in the title. Is it possible to have a wheel that as you scroll through the games it does not change the movie for it? It just continues to play the same movie all the way through and it does not restart each time you scroll? Simply Austin's YouTube
gigapig Posted May 10, 2014 Posted May 10, 2014 Not sure if it's possible, but to me you would need 1 default theme and default vid and set in Hyper HQ to not reload background. If you had different themes I can't see it being possible because the video window changes position, but you never know, anythings possible.
SIMPLYAUSTIN Posted May 10, 2014 Author Posted May 10, 2014 Well the thing I am trying to do, without going into too much detail in this section..... I have an unofficial theme, I must admit I like it. Its for a system which does not have much art or anything for. In the back ground of the theme is a fullscreen video playing for the main menu. What I have managed to get my hands on is all matching cases for said system, but no wheel art. As the list is almost a thousand and have little sources or no sources for said system... I aint got many options What I have done is set the main theme as the default theme too. I have made the wheel art the game boxes running horizontal across the theme. To be honest considering I have little or no art apart from the boxes Im more than pleased with how it has turned out. Problem is that each time I scroll the wheel, it restarts the vid in the background... ruining it If I could find a way to make it continuous whilst I scroll through the wheel, all my dreams will come true, lambs will be born and the sun will break through the clouds like the first day of spring. Simply Austin's YouTube
