Can anyone share Demul xbox 360 conroller configs?
floatingyeti
I can successfully configure standard jamma00 and jamma01 (using method in module notes). But when going through my Naomi and Atomiswave games I realize that for many games I will have to set specifically through the global module settings editor (v.0.5.8 ahk). That looks like a very long and frustrating task.
has anyone uploaded a fully configured "Demul (v0.5.8).ini" for xbox 360 controllers?
That would be amazingly helpful! thanks
  • 4 weeks later...
You dont have to set them up? All I did was set the controls up in Demul using the input configuration tool. Play a game to test and all is good.
Then open your control config file in the Demul folder. Search for the code (its around 10 numbers off top of head). Then go into the module and add the numbers to the controller code. Keep all the other games as default and it worked for me.
Boom!
Thanks for the info austin585.
