uptown47 Posted September 3, 2018 Posted September 3, 2018 Hi there, I've got a set up using Rocketlauncher and Hyperspin and it's all working fine. I've copied the set up to another drive and so have been updating several emulators so that they run on the new drive (rom paths etc) and also have updated the HyperHQ wheel settings etc. All is well apart from MAME. When I try and launch games from Rocketlauncher on MAME - some will run fine but others just show the black "Initializing" screen and then drop out of MAME back to Rocketlauncher. Looking at the rocketlauncher.log it looks like it's trying to find my MAME bios files in the MAME/roms folder but I don't have any BIOS files in there. I'm guessing this is my issue as some games run and others don't ?? (for instance - Simpsons runs fine but Tapper doesn't ??) I'm not sure why this would change as I've only changed the drive that the folders are on but wondered if this could be the cause of my problem and (if so) does anyone know how to change the BIOS path for MAME ? A big thank you for any help you can give me.
thcdgaf Posted September 3, 2018 Posted September 3, 2018 Try looking for midssio.zip place in folder where your roms are let me know if it works or notSent from my H710VL using Tapatalk
uptown47 Posted September 3, 2018 Author Posted September 3, 2018 Thanks thcdgaf, I'll do that as soon as I'm home from work. What is that zip file? And why would I need it when all I've done is move all the folders from one drive to another? Thanks for all your help, it's appreciated
uptown47 Posted September 3, 2018 Author Posted September 3, 2018 On 9/3/2018 at 12:05 PM, thcdgaf said: Try looking for midssio.zip place in folder where your roms are let me know if it works or not Expand I tried midssio but to no avail but I managed to sort it although I'm not sure what the issue is. I'll detail it here in case it helps someone else sort a similar problem... What I did was open a cmd prompt and ran the game from there as per the Rocketlauncher log ("T:\HyperSpin\Emulators\MAME\mame64.exe" tappera -rompath "T:\HyperSpin_ROMS\MAME;T:\HyperSpin\Emulators\MAME\roms" -nowindow -nohlsl_enable -nogl_glsl -video d3d -artwork_crop -nouse_bezels -use_overlays -use_backdrops -nouse_cpanels -nouse_marquees -nofilter -skip_gameinfo) It said that files were missing from "tappera" (the game Tapper). I tried to open the zip file to check but the system said it was corrupt?? It was also a bigger size than my backup file (this was 154Kb as oppose to the other file being 68Kb???). So I replace the file then ran the command again... This time I had less missing files but still had a few and the text mentioned looking in "tapper" as well as "tappera".... So... I looked in the tapper zip file (which was only on my backup folder and NOT in my ROMs folder) and it had the missing files in there so I dropped it in the ROMs folder and now everything works?!??! However, all this *used* to work so has something changed with what files MAME requires from certain game zips or something?? Thanks
thcdgaf Posted September 3, 2018 Posted September 3, 2018 On 9/3/2018 at 7:05 PM, uptown47 said: I tried midssio but to no avail but I managed to sort it although I'm not sure what the issue is. I'll detail it here in case it helps someone else sort a similar problem... What I did was open a cmd prompt and ran the game from there as per the Rocketlauncher log ("T:\HyperSpin\Emulators\MAME\mame64.exe" tappera -rompath "T:\HyperSpin_ROMS\MAME;T:\HyperSpin\Emulators\MAME\roms" -nowindow -nohlsl_enable -nogl_glsl -video d3d -artwork_crop -nouse_bezels -use_overlays -use_backdrops -nouse_cpanels -nouse_marquees -nofilter -skip_gameinfo) It said that files were missing from "tappera" (the game Tapper). I tried to open the zip file to check but the system said it was corrupt?? It was also a bigger size than my backup file (this was 154Kb as oppose to the other file being 68Kb???). So I replace the file then ran the command again... This time I had less missing files but still had a few and the text mentioned looking in "tapper" as well as "tappera".... So... I looked in the tapper zip file (which was only on my backup folder and NOT in my ROMs folder) and it had the missing files in there so I dropped it in the ROMs folder and now everything works?!??! However, all this *used* to work so has something changed with what files MAME requires from certain game zips or something?? Thanks [emoji4] Nice to know but depends which Mame you using cli to verify roms give you an list of stuff missing use command -verifyroms in command prompt as admin as well commands found here https://docs.mamedev.org/commandline/commandline-all.htmlSent from my H710VL using Tapatalk
uptown47 Posted September 3, 2018 Author Posted September 3, 2018 I did a 'verify' and got this info although I'm not really sure what it means??..... romset 1292apvs is best available romset 1392apvs [1292apvs] is best available romset a2600 is best available romset a2600p [a2600] is best available romset advsnha [arcadia] is best available romset apexc is best available romset arcadia is best available romset bndarc [arcadia] is best available romset breakout is best available romset copera is best available romset cpc464p is best available romset cpc6128p is best available romset cx3000tc [vc4000] is best available romset database is best available romset dendy [nes] is best available romset dynavisn [intmpt03] is best available romset ekusera [intmpt03] is best available romset elf2 is best available romset f1392 [1292apvs] is best available romset famicom [nes] is best available romset fforce2 [1292apvs] is best available gamekin3 : gameking3 (524288 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset gamekin3 is best available romset gchinatv [nes] is best available romset genesis is best available romset gx4000 is best available romset h21 is best available romset hanihac [arcadia] is best available romset hmg1292 [1292apvs] is best available romset hmg1392 [1292apvs] is best available romset hmg2650 [arcadia] is best available romset intervsn [ormatu] is best available romset intmpt03 is best available romset itmcmtp3 [intmpt03] is best available romset ixl2000 [arcadia] is best available romset krvnjvtv is best available romset leonardo [arcadia] is best available romset lnsy1392 [1292apvs] is best available romset lvision [arcadia] is best available mac2bios : macs2os_l.bin (524288 bytes) - NOT FOUND - NO GOOD DUMP KNOWN mac2bios : macs2os_h.bin (524288 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset mac2bios is best available romset megadrij [genesis] is best available romset megadriv [genesis] is best available romset megaduck is best available romset mpt05 is best available romset mpu1000 [1292apvs] is best available romset mpu2000 [1292apvs] is best available romset mratlus [plldium] is best available romset myvision is best available romset nes is best available romset nespal [nes] is best available romset oc2000 [krvnjvtv] is best available romset orbituvi is best available romset ormatu is best available romset pasogo is best available pc8401a : pc8401a.bin (98304 bytes) - NOT FOUND - NO GOOD DUMP KNOWN pc8401a : pc8441a.bin (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN pc8401a : sed1330.bin (1472 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset pc8401a is best available romset pce is best available romset pdp1 is best available romset pico is best available romset picoj [pico] is best available romset picou [pico] is best available romset plldium is best available romset pockchal is best available romset polyvcg [plldium] is best available romset pongd is best available romset pongf is best available romset poppympt [intmpt03] is best available romset pp1292 [1292apvs] is best available romset pp1392 [1292apvs] is best available romset prestmpt [intmpt03] is best available romset pv1000 is best available romset rowtrn2k [intmpt03] is best available romset rwtrntcs is best available sarpc : 1203,191-01.bin (2097152 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sarpc : 1203,192-01.bin (2097152 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset sarpc [rpc600] is best available romset sawatte is best available romset sc3000 is best available romset sc3000h [sc3000] is best available romset sg1000 is best available romset sg1000m2 [sg1000] is best available romset sg1000m3 [sms] is best available romset sgx [pce] is best available romset sheenhvc [ormatu] is best available romset soundic [intmpt03] is best available romset spc4000 [vc4000] is best available romset ssem is best available romset supracan is best available romset sv8000 is best available romset svision is best available romset svisionn [svision] is best available romset svisionp [svision] is best available romset svisions [svision] is best available romset tbbympt3 [intmpt03] is best available romset tccosmos [arcadia] is best available romset telefevr [arcadia] is best available romset telngtcs [rwtrntcs] is best available romset tempestm [intmpt03] is best available test410 : rom_41x.bin (512 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset test410 is best available romset tg16 [pce] is best available ti99_224 : 992rom.bin (24576 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset ti99_224 is best available ti99_232 : 992rom32.bin (32768 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset ti99_232 [ti99_224] is best available tmc2000e : 1 (2048 bytes) - NOT FOUND - NO GOOD DUMP KNOWN tmc2000e : 2 (2048 bytes) - NOT FOUND - NO GOOD DUMP KNOWN tmc2000e : 3 (2048 bytes) - NOT FOUND - NO GOOD DUMP KNOWN tmc2000e : 4 (2048 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset tmc2000e is best available romset trakcvg [plldium] is best available romset tryomvgc [intmpt03] is best available romset tunixha [arcadia] is best available romset tvc4000 [vc4000] is best available romset tvg2000 [arcadia] is best available romset tvlinkp [svision] is best available romset tx0_64kw is best available romset tx0_8kw [tx0_64kw] is best available romset uzebox is best available romset vboy is best available romset vc4000 is best available romset vc6000 [1292apvs] is best available romset vdmaster [orbituvi] is best available vic10 : 6703.u4 (256 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset vic10 is best available romset vmdtbase [database] is best available vz200de : vtechv11.u09 (8192 bytes) - NOT FOUND - NO GOOD DUMP KNOWN vz200de : vtechv11.u10 (8192 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset vz200de [laser200] is best available romset wscolor [wswan] is best available romset wswan is best available abc80kb : 053.z5 (1024 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset abc80kb is best available adam_ide : exp.rom (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset adam_ide is best available 3c505 : 3000_3c505_010728-00.bin (8192 bytes) - NOT FOUND BUT OPTIONAL romset 3c505 is best available kb_pc83 : 8048.u1 (1024 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset kb_pc83 is best available hd63484 : hd63484.bin (256 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset hd63484 is best available plus4_sid : gal16v8 (256 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset plus4_sid is best available coco_fdc : disk10.rom (8192 bytes) - NOT FOUND BUT OPTIONAL romset coco_fdc is best available coco_fdc_v11: disk11.rom (8192 bytes) - NOT FOUND BUT OPTIONAL romset coco_fdc_v11 is best available i80130 : 80130 (16384 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset i80130 is best available dragon_fdc : ddos10.rom (8192 bytes) - NOT FOUND BUT OPTIONAL romset dragon_fdc is best available sdtandy_fdc : sdtandy.rom (8192 bytes) - NOT FOUND BUT OPTIONAL romset sdtandy_fdc is best available aprikb : keyboard controller upd7507c.ic2 (2048 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset aprikb is best available kc_d004 : d004v20.bin (8192 bytes) - NOT FOUND BUT OPTIONAL romset kc_d004 is best available mm65k16s : 82s100.6c (65536 bytes) - NOT FOUND - NO GOOD DUMP KNOWN mm65k16s : pal14l4.6d (16 bytes) - NOT FOUND - NO GOOD DUMP KNOWN mm65k16s : pal16l2.16d (16 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset mm65k16s is best available sed1330 : sed1330.bin (1472 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset sed1330 is best available mb90082 : mb90082_char.bin (2048 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset mb90082 is best available tandy2kb : keyboard.m1 (1024 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset tandy2kb is best available trs80m2kb : 65-1991.z4 (1024 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset trs80m2kb is best available v1050kb : 20-08049-410.z5 (2048 bytes) - NOT FOUND - NO GOOD DUMP KNOWN v1050kb : 22-02716-074.z8 (2048 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset v1050kb is best available wangpc_tig : 377-3072.l26 (256 bytes) - NOT FOUND - NO GOOD DUMP KNOWN wangpc_tig : 377-3073.l16 (256 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset wangpc_tig is best available sa1403d : i (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : ii (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : iii (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : iv (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : i (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : ii (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : iii (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : iv (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : i (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : ii (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : iii (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN sa1403d : iv (4096 bytes) - NOT FOUND - NO GOOD DUMP KNOWN romset sa1403d is best available 138 romsets found, 138 were OK. Thanks
Spawk Posted September 4, 2018 Posted September 4, 2018 On 9/3/2018 at 7:05 PM, uptown47 said: I tried midssio but to no avail but I managed to sort it although I'm not sure what the issue is. I'll detail it here in case it helps someone else sort a similar problem... What I did was open a cmd prompt and ran the game from there as per the Rocketlauncher log ("T:\HyperSpin\Emulators\MAME\mame64.exe" tappera -rompath "T:\HyperSpin_ROMS\MAME;T:\HyperSpin\Emulators\MAME\roms" -nowindow -nohlsl_enable -nogl_glsl -video d3d -artwork_crop -nouse_bezels -use_overlays -use_backdrops -nouse_cpanels -nouse_marquees -nofilter -skip_gameinfo) It said that files were missing from "tappera" (the game Tapper). I tried to open the zip file to check but the system said it was corrupt?? It was also a bigger size than my backup file (this was 154Kb as oppose to the other file being 68Kb???). So I replace the file then ran the command again... This time I had less missing files but still had a few and the text mentioned looking in "tapper" as well as "tappera".... So... I looked in the tapper zip file (which was only on my backup folder and NOT in my ROMs folder) and it had the missing files in there so I dropped it in the ROMs folder and now everything works?!??! However, all this *used* to work so has something changed with what files MAME requires from certain game zips or something?? Thanks [emoji4] This is normal behaviour for a "split" rom set. Tappera is a clone of Tapper so it will not run unless Tapper is in the rom folder as well (or you move the needed files like you did).Sounds like you use a "roms only" filter. I used this as well at first as it seemed to make the most sense. However, now I find it better to keep the full set and disable games I don't want to show in the wheel via the xml database. That way I can disable Puckman and Pacman will still load/run because the Puckman file is still there.Sent from my SM-A520W using Tapatalk
uptown47 Posted September 4, 2018 Author Posted September 4, 2018 ** Edit ... it's okay. I've found a brilliant tool called Hypermint made by Horsey - Hi Spawk Yes, I do use the "roms only filter" as I only have about 40 games and didn't want to have to keep manually editing the database.xml everytime I changed a few around. Is there an easy way of editing the database then to keep it synched with what roms are in your actual folder? Or do you edit your xml by hand every time you change a game? Thanks
